Strange stuff
Hello everyone,
I have a Parallax BOE and am using it to control some servos
connected to the servo headers pins 14 and 15, but I am seeing some
strange things I can't explain. When I have a servo connected to pin
14 and do a looping pulsout to pin 15, the servo connected to 14
moves. Why is this? Here is my code:
main:
PULSOUT 15, 1000
PAUSE 20
GOTO main
Even if there is no servo connected to pin 15, the pin 14 servo still
moves very slowly. However if I add the following one line to the
program before the "main" routine this doesn't happen:
pulsout 14, anything
Why should I have to pre-pulse servo 14 to keep it from wandering
while pulsing servo 15? Please help.
-Nickel
main:
PULSOUT 15, 1000
PAUSE 20
GOTO main
-Nickel
"bleading" on to another pin. One way of fixing it is to set you pin to the
servo you want to stay still to a low state. This should keep the servo from
wandering:
for example
start:
low 14
pulsout 15,?????
goto start
of course when you want the servo to move again, well you know what to do. I
hope this helps
nickel152 <nickel152@y...> wrote:
Hello everyone,
main:
PULSOUT 15, 1000
PAUSE 20
GOTO main
-Nickel
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
had this problem. More of a curious annoyance than a problem really.
-Nickel
--- In basicstamps@yahoogroups.com, Walt Trowbridge <wdt3_03@y...>
wrote:
> ive had the same problem with some robots too. I think its because
the signal is "bleading" on to another pin. One way of fixing it is
to set you pin to the servo you want to stay still to a low state.
This should keep the servo from wandering:
> for example
> start:
> low 14
> pulsout 15,?????
> goto start
to do. I hope this helps
> Hello everyone,
pin
> main:
> PULSOUT 15, 1000
> PAUSE 20
> GOTO main
still
> -Nickel
Subject and Body of the message will be ignored.
> Do you Yahoo!?
