Multiple ic''s tied together
Devices with Chip Select lines are usually designed to share a common
"buss" -- so I would suggest sharing clock and data lines and allowing
separate control for the CS. Using this scheme you can expand your
system more easily to larger number of devices using common interface
chips (like the 74HC138) to expand your CS selection.
-- Jon Williams
-- Dallas Office
From: cn00728 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oRYI2iyz0DIBXHmvo8-iE2cRSLKSe1-e_SPPFC4B3hNv1JCGQ4ggcMHbm135GN1NalQTtWfkOOAg]cn00728@y...[/url
Sent: Wednesday, November 26, 2003 12:12 AM
Subject: [noparse][[/noparse]basicstamps] Multiple ic's tied together
Hello,
To save on IO lines on my Stamp, I was thinking of tieing the cs and
clock lines together on identical A/D chips so only two lines are
needed to control all of them. The data line would go to it's own
separate IO port on the Stamp for each chip.
Is this right?
Thank you,
John
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
-- Jon Williams
-- Dallas Office
Hello,
Is this right?
Thank you,
John
abuse@p....
