attaching a relay on an output pin
Hi, I'm trying to attach a 6vdc trigger industrial strength coil
relay to an output on my basic stamp 2. It is being used to control
the on/off of a 110 volts, 6 amps ac motor. But right now i'm just
stuck at making sure the relay works. I'v tested the relay that I
was planning to use and it works fine with a manual switch. But when
I hooked it up to the stamp it won't switch states. The led attached
to the same output is going from low to high, but the relay is not
following, it is getting power it's just not being triggered. I
don't know what I'm missing? I would appreaciate any and all
suggestions...Oh and I did have it hooked up to an opto isolater 4n32
but it didn't work so I began to strip it down and now I'm just as
confused as ever.
thanks jeff
confused as ever.
thanks jeff
background and I'm guessing that the stamp is not sourcing
enough current for the relay. Relay's typically take a
substantial amount of current to trigger. You might try
looking at the specs for the relay and the output pin of
the stamp that you are using. Probably you will have to
use a transistor to switch a high current to the coil of
the relay using the stamp as the trigger. Let me know if
you need more information.
On Wed, 26 Nov 2003 05:35:00 -0000
>strength coil
>to control
>i'm just
>relay that I
>switch. But when
>led attached
>relay is not
>triggered. I
>all
>isolater 4n32
>I'm just as
>confused as ever.
>thanks jeff
>from the same email address that you subscribed. Text in
>the Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to
>http://docs.yahoo.com/info/terms/
Darlington transistor which is triggered by the Stamp. If the relay operates at
6VDC
then the voltage to the Darlington must be 6VDC. Connect the positive side of
your relay to 6V, the negative side to the Darlington output. A high from
the Stamp will turn the Darlington on, sending the collector to ground, which
will close your relay.
Sid
site:
jim
http://www.geocities.com/jimforkin2003/
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=io7NuE5WAeKKQX0mS7peaND6t0RP3MxRM6wD_UFZ6augRxnAXLePKvC1WiWIEwhW0CZgORAs]Newzed@a...[/url
Sent: Wednesday, November 26, 2003 10:37 AM
Subject: Re: [noparse][[/noparse]basicstamps] attaching a relay on an output pin
You can not drive the relay with a Stamp output pin. You must use a
operates at 6VDC
of
which
Sid
Darlingtons are normally used when you need a very high gain.
Darlingtons requires a more carefull design, the Vcesat is higher
that a plain bjt device.
Also the Icb and Ice leakage currents could be a problem if the
circuit is not designed properly.
a simple npn or pnp or even better a mosfet that is the only thing
you need.
http://www.al-williams.com/components.htm for an IRL520). These will turn on
hard to ground when you put 5V on the gate and they are good to 9A (with
heat sinking).
The only trick I use when using them is to put a 100K or so resistor from
the gate to ground. This doesn't really do anything for the circuit, but it
makes it less likely that you will damage the part while handling the
circuit -- it gives any ESD a place to go instead of through the gate oxide!
Oddly enough, FETs are really what they were looking for when they developed
the transistor. It just took awhile to get the FETs right and then longer
still to make them handle power. But now they are cheap and easy to use so
unless you are shaving pennies, I usually just use the FETs for everything.
Al Williams
AWC
* New: Read position data: http://www.al-williams.com/pak11.htm
> From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QBJw-grLAvg3eqU5ow_7MQaZyMMvOD2MYddWPXZDJDOQUrP3U4jAHlNZSXAXcPCSqmdzHfi5]Newzed@a...[/url
> Sent: Wednesday, November 26, 2003 9:37 AM
> the relay operates at 6VDC
> positive side of
> A high from
> to ground, which
> Sid
relays, lamps, etc. to stamps.
jim
From: STEVE JOHNSON [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=p2S0dW1YtoVyv8I54voXzgRJzGXDJ4HgZQ2871YCGUdTh66aqmIAmu4vEXhxgBP6BbvRomJh8IOV-i8GgIhdaQ]cmmdrdata@c...[/url
Sent: Wednesday, November 26, 2003 10:14 AM
Hi, I'm no stamp expert but I do have an electronics
>strength coil
>to control
>i'm just
>relay that I
>switch. But when
>led attached
>relay is not
>triggered. I
>all
>isolater 4n32
>I'm just as
>confused as ever.
>thanks jeff
jim
From: jeff alten [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qVvwnv-3e0xAgWRd2dd24lod_Y3UxIeQtc1s9RDMx54TV3dFMc4XoiMsfDCXmlGVjs4V3yNtpITjTL0]jeffalten@h...[/url
Sent: Wednesday, November 26, 2003 12:07 PM
I have no idea what a darlington transistor is, are there many different
ones with different specks or just a couple and where would I be able to
find the right one for me?
operates at 6VDC
side of
which
> Sid
operates at 6VDC
side of
which
> Sid
to only be putting out 3.52 volts and the coil does need about 5 volts. I
tried using a tip 120 & 125, because I've used them to boost the voltage
from a 555 but it doesn't seem to work with Basic Stamp. Is there any
specific kind of transistor.
thanks, jeff
Sent: Wednesday, November 26, 2003 9:13 AM
> >strength coil
> >to control
> >i'm just
> >relay that I
> >switch. But when
> >led attached
> >relay is not
> >triggered. I
> >all
> >isolater 4n32
> >I'm just as
> >confused as ever.
> >thanks jeff
jeffalten@h... writes:
ULN2003 - seven channels - Digikey
UILN2803 - eight channels - Digikey
Sid
<25ma draw) to stamp pins directly, no problems whatsoever. I designed
some electronics for a system that did hydrogen-oxygen hydrolysis and a
timed explosion of gas.
On Wed, 26 Nov 2003, Jim Forkin wrote:
> check out http://www.geocities.com/jimforkin2003/ for schematics to hook up
> jim
> From: STEVE JOHNSON [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=--a2T1JCi2lf2HmJ6BxhJAt6e2ZUhjKo02XUOsnlQNPkVC73MJt0yVNxtXyQv-7BWaasYkoIuyf4nAi_]cmmdrdata@c...[/url
> >strength coil
> >to control
> >i'm just
> >relay that I
> >switch. But when
> >led attached
> >relay is not
> >triggered. I
> >all
> >isolater 4n32
> >I'm just as
> >confused as ever.
> >thanks jeff
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
can even tie multiple inputs together and outputs to
get enough output don't forget the quenching diode
across the realy coil good luck
--- jeff alten <jeffalten@h...> wrote:
> Hey steve thanks for the advice, I'm no expert in
> either. The stamp seems
> Stamp. Is there any
> thanks, jeff
> From: "STEVE JOHNSON" <cmmdrdata@c...>
> output pin
> electronics
> sourcing
> take a
> might try
> pin of
> have to
> coil of
> know if
> industrial
> > >strength coil
> being used
> > >to control
> right now
> > >i'm just
> the
> > >relay that I
> manual
> > >switch. But when
> states. The
> > >led attached
> the
> > >relay is not
> being
> > >triggered. I
> any and
> > >all
> an opto
> > >isolater 4n32
> and now
> > >I'm just as
> > >confused as ever.
> > >thanks jeff
> Text in
> ignored.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
http://companion.yahoo.com/
alw@a... writes:
> A darlington will work. I personally like to use a logic level MOSFET (see
> heat sinking).
Happy Thanksgiving, Al.
I've never used a MOSFET - I don't even have one - but would like to know
how. Is the gate like the base, the drain like the collector and the source
like
the emitter?
Do MOSFETs come in arrays like the ULN2803? One of my boards has 13 relays,
and 13 TO220 chips would take up a lot of room. If I wanted to use one to
operate a relay, would I add a diode across the drain and the source - cathode
to
drain?
Sid
Newzed@a... writes:
like
the emitter?
YES
