Need help for serial communication
I'm new with Stamps. My task is to send and receive 16 byte serial
data (telegram) to and from another control unit by serial
communication. First, building up the telegram according to the
prototype and send out. Then receive(read) the back telegram;
disassemble the telegram and make control.
I'm not sure of the code for getting data from
the SIN and send out data from SOUT. Could anyone help me on the
code? Thanks.
code? Thanks.
MyBaud VAR 84 + 16384 ' 9600 baud, with Inversion
SerData VAR WORD
MAIN:
SEROUT 16, MyBaud, [noparse][[/noparse]">",13]
SERIN 16, MyBaud, [noparse][[/noparse]DEC SerData]
SEROUT 16, MyBaud, [noparse][[/noparse]DEC SerData, 13]
' This will 'pend' until data arrives
GOTO MAIN
Use the 'terminal' window, set it to 9600 baud.
Type in a number, then send with the 'enter' key.
"16" here is NOT a 'real' pin, it indicates to
the stamp to use the SIN/SOUT pins.
> code? Thanks.
zy93@h... writes:
> code? Thanks.
If you want to set up serin to receive a string of bytes, you first have to
have a byte array. For instance if you want to receive 4 bytes, you would
define a variable:
serstring var byte(4)
This takes up 4 bytes of your available RAM.
You would then write
serin pin, baud, [noparse][[/noparse]STR serstring\4]
You only have 26 bytes availbe for variable storage, so you would have to
manage your variables very carefully.
Serouting is no problem . All you have to do is write
serout pin, baud [noparse][[/noparse]"This is a test message"], cr
Receiving it is where the problem comes in. You can make your serstring a 16
byte variable as long as you have RAM available. Be sure and use a delay
when serouting so the serin has enough time to read the string.
Sid Weaver
W4EKQ
Port Richey, FL
