rotary encoder
Hi
I like to control 4 gear motors for positioning , each motor with 2 sensors, I
use as
A and B channel.
I would like to count the revolutions of each Motor
and for this I would like to use as less time as possible.
My hardware is not ready jet, I have no chance to test my programme parts,
but like to start programming, to find some basic ways.
On Tracy Allens Website I red about state machine.
My result is this line:
cntM1= (old.BIT0^new.BIT0*2-1)*(new.BIT0^old.BIT0)+cntM1
This line should do: (see a part of the program below)
1) to add one to my counter "cntM1" if the motor runs CW
2) to subtract one of my counter "cntM1" if the motor runs CCW
3) do nothing if there is no change from old state to new state
is this line doing what I think ?
and if yes, is it working in the quickest way ?
the first phrase should add or subtract one
the result is 1 or -1 ??
the second multiple these "one" with zero or with one,
depending if there was a change between old and new state
I don't know if I understand every thing correct ?
thanks for help or comment.
Heinz Germany
'{$STAMP BS2p}
' 4 encoders, signals on P8 thru P15 (by bit pairs)
old VAR Nib ' previous state
new VAR Nib ' current state
cntM1 VAR Word ' for position motor 1
cntM2 VAR Word ' for position motor 2
cntM3 VAR Word ' for position motor 3
cntM4 VAR Word ' for position motor 4
DIRC=0 ' make port C inputs
old=INH ' read initial state of inputs
SERIN 'GET the stop information for each motor from my Keyboard and Display
stamp
' then start the 4 Motors
decode:
new=INH ' read new states from all 4 encoders, eight bits
'this lines are for Motor and switch control like
'compare stop-value with cntM1, slow down the motor1, stop the motor1
'check a lot of switches
cntM2= (old.BIT1^new.BIT1*2-1)*(new.BIT1^old.BIT1)+cntM2
cntM3= (old.BIT2^new.BIT2*2-1)*(new.BIT2^old.BIT2)+cntM3
cntM4= (old.BIT3^new.BIT3*2-1)*(new.BIT3^old.BIT3)+cntM4
old=new
GOTO decode
use as
A and B channel.
Heinz Germany
'{$STAMP BS2p}
stamp
decode:
old=new
GOTO decode
>sensors, I use as
>A and B channel.
The direction of rotation is determined by the "cross terms", so it
should read more like this:
cntM1= (old.BIT0 ^ new.BIT1 * 2 - 1)*(new ^ old & 3 max 1) + cntM1
By cross terms, I mean that bit 1 of the new reading is XORed with
bit 0 of the old reading. That is, each time you read the state of
the encoder, you pick up a new value of bit 0 from sensor A and bit 1
from sensor B. That is the first term in the formula, and the result
is either +1 or -1 for the two directions. That is contingent upon
there having been any rotation at all, There has to have been a
change in state between old and new. That is what the second term
decodes, (new ^ old & 3 max 1), which is 1 if there is a change, zero
otherwise. The &3 comes in because you are using bits 0 and 1 for
sensors A and B. Multiplying the two terms together gives either
0, or +1 or -1 as required, to add to the old value of the count.
There is a diagram of the state transitions to show how the cross
terms work, at this URL:
http://www.emesystems.com/BS2fsm.htm#twobit%20encoder
Here is another way to code it:
IF new ^ old & 3 THEN
SELECT old.BIT0 ^ new.BIT1
CASE 0
cntM1=cntM1-1
CASE 1
cntM1=cntM1+1
ENDSELECT
ENDIF
cntM1= (old.BIT0 ^ new.BIT1 * 2 - 1) + cntM1
That also makes the count conditional on there having been a change
of state, then deciding which direction from the cross terms.
I'm not sure what would be fastest. The web page above has an
extension to four encoders where it processes the logic from all 4 in
parallel. That speeds things up considerably. (I took a look at it
and corrected a typo in tha program on the web page, and edited the
explanation a bit). Be that as it may, the Stamp is not fast at
doing all the steps, so it cannot keep up with encoders putting out
any more than 100 Hertz, if that much. The same logic programmed in
assembly in an SX could keep up with just about anything.
-- Tracy
>Heinz Germany
> '{$STAMP BS2p}
>and Display stamp
>decode:
> old=new
>GOTO decode
Hi Randy
Thanks for Your very helpful mail
I still have some problems to understand completely Tracy's
explanation.I have to take time to think it over.
for the project with the 4 Motors I need a little bit faster decoding
about 120 hz
the Bs2p is properly not fast enough too ?
on the USDicital page http://www.usdigital.com/products/ls7183-ls7184/
I see the IC LS183 and LS184
quadrature encoder to counter (up / down clk).
quadrature encoder to counter (clk / direction).
They look useful to add to the Stamp
Do You have experience, or even sample code with this IC's ?
Still I don't know if the Bs2p can count the pulses of
4 of this IC's and compare the counts and stop the 4 Motors and check
some switches between.
It is difficult for me to imagine the needed time??
An other project I started is to change the angel
of an milling machine by an slow gear motor and an optical encoder
speed about 50hz.
I believe this could be to do with the Stamp2p ?
starting with Tracy's pages
is really helpful
Randy,
do You like to send me an copy of Your encoder code,
to collect some ideas for quicker coming up ?
Heinz
In regards to the speed, I have done a quadrature encoder with a basic stamp
and you would be very hard pressed to get the stamp to read accurately even at
100Hz. I would say you need to keep the frequency around or below 75Hz.
This was using a Basic Stamp 2 IC so the recommendation of using an SX with
assembly would be a good suggestion.
When I did the Basic Stamp 2, I found it would read from the encoder even a
little over 100Hz but was missing at least half of the pulses as it could not
process the incoming data fast enough.
Another way you might want to try is using one of the encoder interface chips
from U.S. Digital. Here are some links to their site: Home: <A
HREF="http://www.usdigital.com/">Optical
Encoders, Inclinometers & Motion Control Components @ US Digital</A>
Page with IC's, interface chips: <A
HREF="http://www.usdigital.com/products/ics.shtml">ICs (LSI Chips) @ US
Digital</A>
I hope this helps
Randy Abernathy
4626 Old Stilesboro Road
Acworth, GA 30101
Ph / Fax: 770-974-5295
E-mail: cnc002@a...
I furnish technical support, repair, and other related services for your
industrial woodworking machinery. My background as Senior Service Engineer for
the
SCMI Group for nearly fifteen years with factory training, combines with my
extensive background in electronics, mechanics, pneumatics, electrical and CNC
machinery to offer you needed support for your machinery.
Sent: Monday, November 24, 2003 7:06 AM
Subject: Re: [noparse][[/noparse]basicstamps] rotary encoder "ntM1=
(old.BIT0^new.BIT0*2-1)*(new.BIT0^old.BIT0)+cntM1"
>Hi
>sensors, I use as
>A and B channel.
CASE 0
cntM1=cntM1-1
CASE 1
cntM1=cntM1+1
ENDSELECT
ENDIF
-- Tracy
>Heinz Germany
> '{$STAMP BS2p}
>and Display stamp
>decode:
> old=new
>GOTO decode
from the same email address that you subscribed. Text in the Subject and Body
on a BS2pe at 8 milliseconds per scan, or, on a BS2p, faster at 3.2
milliseconds per scan.
Oh, this is important, I took out the debug statement that shows the
state of each counter. That serial output of course ate up a huge
amount of time.
So a BS2p could conceivably be dedicated to scan a set of encoders
for a frequency up to about 300 Hertz, so long as it does not have to
do anything else. Don't push it--it can not be allowed to miss any
state changes. With a BS2p, it is not out of the question to scan at
the 125 Hertz rate and still have time to test a couple more switches
and to test the counts for a target value. Do look into the other
chips though. All I had to use it for was a tide gage encoder, which
moves slowly!
-- Tracy
>Hi Tracy,
>Hi Randy
>about 120 hz
>speed about 50hz.
>is really helpful
>Randy,
>Heinz
>US Digital</A>
>I hope this helps
>Randy Abernathy
>Acworth, GA 30101
>E-mail: cnc002@a...
>Engineer for the
> From: Tracy Allen
> >Hi
> >sensors, I use as
> >A and B channel.
> CASE 0
> cntM1=cntM1-1
> CASE 1
> cntM1=cntM1+1
> ENDSELECT
> ENDIF
> -- Tracy
> >Heinz Germany
> > '{$STAMP BS2p}
> >and Display stamp
> >decode:
> > old=new
> >GOTO decode
>Subject and Body of the message will be ignored.
