8 data pins — Parallax Forums
8 data pins
edited 2003-11-22 17:35 in General Discussion
hi guys, how would one read 8 data pins from a counter chip?
    edited 2003-11-22 16:01
    You will want to wire the 8 data pins into the stamp ports 0~7 or 8~15.
    Pins 0~7 can be read as IN LOW, while 8~ 15 IN HIGH.
    ken
    edited 2003-11-22 16:10
    8~15.
    > ken
    so i would hold a pin high on the chip i am using and then shiftin
    the data as a byte from pins 0-7, and store that data into a variable?
    edited 2003-11-22 16:14
    >ken
    Make that INL and INH for proper compilation.
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-11-22 16:17
    No....well not yet....
    I was assuming the counter chip was a parallel output.....What is the number
    of the counter chip you are using to count, and explain a little about your
    application. The Stamp does have a COUNT instruction.
    Ken
    edited 2003-11-22 16:20
    Thanks bruce......
    ken
    >ken
    the number
    about your
    > Ken
    variable?
    the chip i am using is a LS7166, i am attempting to use this to read
    quadrature outputs from an encoder, i beleive the data output is
    parallel, 24 bit, the data is sent in three bytes
    mark
