how to increase BS2 I/O pins? — Parallax Forums
edited 2003-12-02 20:58 in General Discussion
could somebody give me a solution to create extra I/O pins for my
BS2 ?
    edited 2003-11-21 22:39
    See 74HCT595 for 8 outputs, 74HCT165 for 8 inputs.
    Use SHIFTIN/SHIFTOUT for getting/outputting data.
    You can also use the 'p40, it has more I/O pins.
    > BS2 ?
    edited 2003-11-21 23:33
    In a message dated 11/21/2003 6:29:23 PM Eastern Standard Time,
    forbigmen@a... writes:
    > BS2 ?
    If you just want extra output pins, you use a 74HC595 serial shift register.
    This takes four I/O lines but will give you eight outputs. By daisy-chaining
    another 595 and using one more I/O line, you can get 16 outputs with five I/O
    lines.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-11-22 00:51
    Outputs... 74HC595
    Inputs.... 74HC165
    Mixed..... PCF8574 (I2C)
    These are all simple, inexpesive devices and you can find source code
    for each on our web site.
    -- Jon Williams
    -- Dallas Office
    From: Martial [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YSIql9jpRdyH3gUnhB_Dq7xztPwWlundfSguY36nDzP-6RL65X8-_LBbPreTwoy_FJ_eSNwS3uAvSsfx]forbigmen@a...[/url
    Sent: Friday, November 21, 2003 4:30 PM
    Subject: [noparse][[/noparse]basicstamps] how to increase BS2 I/O pins?
    BS2 ?
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-11-22 17:22
    I've used Analog multiplexers, Texas instruments CD4067BE. It's a 16
    channel MUX that basically is a digitally controlled rotary switch.
    You can connect 16 devices to 1 Stamp pin. You give up four Stamp
    pins to control the switch position, but get 16 in return. They also
    make an 8 channel MUX which requires only 3 I/O. These MUXes don't
    work well though with serially controlled devices. There is also
    an "on state" resistance associated with the device that you need to
    be aware of if your connecting a bunch of RC timing networks (pseudo
    analog interface), it's not insignificant for purposes of determining
    the time constant. But it works well. Back when I was using RCTIME
    for analog input I was running 9 analog inputs into one Stamp pin.
    Since then I've pretty much dropped those and gone A to D for inputs
    anyway. My favorite is the MAX186 from Maxim. 8 channels of 12 bit
    A/D and only requires 3 I/O to control. Despite the name, it's not
    just for analog signals, you can sample digital devices with it also.
    As others have mentioned you can daisy chain these devices together
    and use the enable lines to select which one you want, dramatically
    increasing your I/O. Best of luck.
    -Dave
    > BS2 ?
    edited 2003-11-22 18:40
    Another option is to use a shift register, like a 74hc595, or for input and
    output expansion a 74ls299. The parallax websight has code and hook up examples
    using the 74hc595.
    ken
    > BS2 ?
    edited 2003-11-23 15:01
    the easy way that I have found to connect many Inputs / Outputs to
    the BS2 is with the PCF8574(A) 8 bit I/O expander from Texas
    Instrument. This little device is controlled by using the I2C bus so
    it only uses 2 IO pins on the BS2. It is possible to daisy chain 16
    chips together for a total of 128 I/O lines using only 2 I/O on the
    BS2. NOTE: that will be using (8) PCF8574 and (8) PCF8574A. each bit
    is individually programmable and latched at the output.
    This is what I am currently using to control 8 CFL outdoor lights
    around my house. The BS2 interfaces with 8 25 amp SSR. (I know
    overkill but they were free) The PCF8574 has high current outputs,
    total of 100ma, plenty to directly drive LEDS, SSR, etc. of course if
    you need more current drive you can always tie in (8) 2N2222 NPN's
    This chip, PCF8574, is available from www.digikey.com for only $2
    http://www.digikey.com/scripts/us/dksus.dll?Detail?Ref=117374&Row=50850
    The datasheet can be found at
    Daryl
    At 06:51 PM 11/21/2003, you wrote:
    >Outputs... 74HC595
    >Inputs.... 74HC165
    >-- Jon Williams
    >-- Dallas Office
    >From: Martial [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZRAufsIOnaUfZQkpBd0i9xRPPTYKHxbd6w8cgB2B-VgOGI8J5XMIouM8ltA7SW6N9nggTb3DCOsR]forbigmen@a...[/url
    >BS2 ?
    >abuse@p....
    >from the same email address that you subscribed. Text in the Subject and
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-12-02 20:52
    > BS2 ?
    To increase Digital I/O on the BS2, concider using the PCF8574 or
    the PCF8574A or their equivalents. The first part is a standard 8-bit
    'quasi-bidirectional' I/O that is address settable. The second part is
    the same as the first, except that you can connect 16 devices with
    software and hardware addressing. The PCF8574 can only have a maximum
    of 8 parts connected to the I2C bus. Both parts are I2C bus
    architecture. In theory you can have up to 64 I/O lines with the
    PCF8574 or 128 I/O lines with the PCF8574A. Both parts are available
    in a through-hole DIP package, SOIC (16-pin) or SSOP20 (20-pin)SMT.
    The I2C protocols can be found for using the BS2, BS2e or BS2sx with
    software. But the BS2p24, BS2p40 or BS2pe have a built in protocol for
    using an I2C part (I2CIN and I2COUT).
    For more information on this, refer to the following websites:
    http://www.parallax.com/
    http://www.emesystems.com/BS2links.htm
    http://www.phanderson.com/stamp/
    http://focus.ti.com/docs/prod/folders/print/pcf8574.html
    http://focus.ti.com/docs/prod/folders/print/pcf8574a.html
    http://www.semiconductors.philips.com/pip/PCF8574T.html
    I am currently attempting to work with the PCF8574 using a BS2pe
    for a large-scale datalogging project. So as I go, I may have more
    information. I am using the PCF8574 to work as address, data and
    control registers to interface the BS2pe system to an AMD FLASH memory
    device to expand data storage. Any other questions, I will try to
    answer them.
    Bill, KC9CFO
    Another chip to consider is the MCP23016 from Microchip. I find it a
    bit easier to use and it has better sink/source ratings than the
    PCF8574. For those that are interested I'll post my MCP23016 demo in
    the files section.
    -- Jon Williams
    -- Dallas Office
    From: wschini03 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JZPtsuW206vmo5FJlo69pyYAkvn27guT0TVWneO46QCu6yPvJZ7F3_x3eXzafBEDHs8H4D1KIo6T5gMXcfw]wschini03@y...[/url
    Sent: Tuesday, December 02, 2003 2:53 PM
    Subject: [noparse][[/noparse]basicstamps] Re: how to increase BS2 I/O pins?
    > BS2 ?
    software and hardware addressing. The PCF8574 can only have a maximum of
    8 parts connected to the I2C bus. Both parts are I2C bus architecture.
    In theory you can have up to 64 I/O lines with the PCF8574 or 128 I/O
    lines with the PCF8574A. Both parts are available in a through-hole DIP
    package, SOIC (16-pin) or SSOP20 (20-pin)SMT. The I2C protocols can be
    found for using the BS2, BS2e or BS2sx with software. But the BS2p24,
    BS2p40 or BS2pe have a built in protocol for using an I2C part (I2CIN
    and I2COUT).
    http://www.parallax.com/ http://www.emesystems.com/BS2links.htm
    information. I am using the PCF8574 to work as address, data and control
    registers to interface the BS2pe system to an AMD FLASH memory device to
    expand data storage. Any other questions, I will try to answer them.
    Bill, KC9CFO
    abuse@p....
