Sending variables between stamp
what im trying to do is, have two basic stamp 2's setup. The first
one would perform a loop to gather sensor input data, and the second
stamp would perform the output data. Both stamps would be running
two different programs. I want to try to "network" work the two
together so the first stamp that performs the sensor input to send
its data result's to the second stamp to be used in its own program...
im to clear on how to use the shiftin/out commands ( i was thinking
that be best way to send information between the to) but below is
some programs i shot together real quick give a idea of what i want
to do with the two stamps
the first stamp will have two MAX187 Analog digital convert's
gathering anlog values to be stored as variables in the code for the
stamp.
'{$STAMP BS2}
'{$PBASIC 2.5}
TB_POS VAR WORD
MAP_SEN VAR WORD
INJECT VAR WORD
X VAR WORD
X0 CON 1000
X1 CON 1100
X2 CON 1200
X3 CON 1300
X4 CON 1400
X5 CON 1500
X6 CON 1600
X7 CON 1700
MAIN:
HIGH 1
LOW 1
SHIFTIN 2,0,MSBPOST,[noparse][[/noparse]TB_POS\3] 'get value of sensor 1
HIGH 4
LOW 4
SHIFTIN 5,3,MSBPOST,[noparse][[/noparse]MAP_SEN\4] 'get value of sensor 2
LOOKUP TB_POS ,[noparse][[/noparse]x0,x1,x2,x3,x4,x5,x6,x7],X 'this is part of my 3d
table that will get a 3rd variable for the correct injector width
SHIFTOUT 10, 8, MSBPOST,[noparse][[/noparse]INJECT] ' this part of program will then
send the correct pulsewidth that is calculated from the 3d table,to
the second stamp. So that the 2nd stamp will run its own program
with the correct variable sent from the first stamp
end of program****
the second stamp program is below, this program is used to perform
the triggering of when to fire the injector's
'{$STAMP BS2}
'{$PBASIC 2.5}
PULSE_WIDTH VAR WORD 'variable to be entered from the first stamp
INPUT 14
INPUT 13
INPUT 10
OUTPUT 12
OUTPUT 11
BOOTUP:
IF IN14 = 0 THEN STUCK
GOTO MAIN
STUCK:
GOTO MAIN
INJECT1:
PULSOUT 12, PULSE_WIDTH
IF IN14 = 0 THEN MAIN2
GOTO MAIN3
INJECT2:
PULSOUT 11, PULSE_WIDTH
IF IN13 = 0 THEN MAIN4
GOTO MAIN
MAIN: 'MAIN loop, this part of
program will run looplessly , getting information from the sensor
stamp to be used once its triggred from the if then command.
SHIFTIN 10,8,MSBPOST,[noparse][[/noparse]PULSE_WIDTH\4]
IF IN14 = 0 THEN INJECT1
GOTO MAIN
MAIN2:
GOTO MAIN3
MAIN3:
IF IN13 = 0 THEN INJECT2
GOTO MAIN3
MAIN4:
GOTO MAIN
***end of program
Over all the two s tamps would be running on different cycles , my
goal is to have the second stamp thats running the injectors to
update it self from its own request from the first stamp , so it will
then shiftin the results of what the other stamp has stored in its
variable ...
please help if anyone can help me
Sean....
stamp.
'{$STAMP BS2}
'{$PBASIC 2.5}
TB_POS VAR WORD
MAP_SEN VAR WORD
INJECT VAR WORD
X VAR WORD
X0 CON 1000
X1 CON 1100
X2 CON 1200
X3 CON 1300
X4 CON 1400
X5 CON 1500
X6 CON 1600
X7 CON 1700
MAIN:
HIGH 1
LOW 1
HIGH 4
LOW 4
end of program****
'{$STAMP BS2}
'{$PBASIC 2.5}
INPUT 14
INPUT 13
INPUT 10
OUTPUT 12
OUTPUT 11
BOOTUP:
GOTO MAIN
STUCK:
GOTO MAIN
INJECT1:
GOTO MAIN3
INJECT2:
GOTO MAIN
GOTO MAIN
MAIN2:
GOTO MAIN3
MAIN3:
GOTO MAIN3
MAIN4:
GOTO MAIN
***end of program
variable ...
Sean....
'Open Collector' options is the best way
to connect two stamps. Much simpler than
trying to synchronize a SHIFTIN/SHIFTOUT pair.
--- In basicstamps@yahoogroups.com, "djrevolution99"
second
program...
the
> stamp.
> '{$STAMP BS2}
> '{$PBASIC 2.5}
> TB_POS VAR WORD
> MAP_SEN VAR WORD
> INJECT VAR WORD
> X VAR WORD
> X0 CON 1000
> X1 CON 1100
> X2 CON 1200
> X3 CON 1300
> X4 CON 1400
> X5 CON 1500
> X6 CON 1600
> X7 CON 1700
> MAIN:
> HIGH 1
> LOW 1
> HIGH 4
> LOW 4
> end of program****
> '{$STAMP BS2}
> '{$PBASIC 2.5}
> INPUT 14
> INPUT 13
> INPUT 10
> OUTPUT 12
> OUTPUT 11
> BOOTUP:
> GOTO MAIN
> STUCK:
> GOTO MAIN
> INJECT1:
> GOTO MAIN3
> INJECT2:
> GOTO MAIN
> GOTO MAIN
> MAIN2:
> GOTO MAIN3
> MAIN3:
> GOTO MAIN3
> MAIN4:
> GOTO MAIN
> ***end of program
will
> variable ...
> Sean....
The SHIFTIN/SHIFTOUT commands on the Stamp can be master only, not
slave, so you cannot use them to share data between two Stamps.
As others have said, SERIN/SEROUT are the way to go, especially if
you can add a flow control line. You might find something helpful at
this URL...
http://www.emesystems.com/BS2rs232.htm#MasterSlave
-- regards,
Tracy
