Connecting BS2 to HyperTerminal
Archiver
Does anyone know how to connect BS2 to HyperTerminal?
I want the BS2 which is collecting data to just send out data to
HyperTerminal periodically (every 1 sec.).
But I don't want to use pin0 to pin15, which are used up.
You need to use the DEBUG command. It is a special case of the SEROUT
instruction which uses the programming connector of the BS2 at 9600 baud.
The manual explains how to use it. Good luck.
Best regards,
Russell Warburton
email: russell@w...
website: http://www.warburtech.com
telephone: +44 (0)7814 044 754
Sent: Tuesday, November 18, 2003 12:49 PM
Subject: [noparse][[/noparse]basicstamps] Connecting BS2 to HyperTerminal
These are referenced by PBASIC both as pin 16.
Note that the stamp replies any byte it receives through SIN, this
is a side effect of the line driver hardware. As long as you just
receive data from the stamp, this should not affect you.
regards
adrian
just use DEBUG and set Hyperterminal to 9600 baud.
-- Jon Williams
-- Dallas Office
From: yellowniter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DFyJ7eFGiqvXKr1D4LlIpBje169MZ_cWBJfcuBtkMk3gXDfly2ebEJ27zXMKB9sT0dxkkxdfI-QN9NJzy1h_]yellowniter@y...[/url
Sent: Tuesday, November 18, 2003 6:49 AM
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Thus:
MyData VAR Word
MyBaud CON 84 + 16384 ' 9600 Baud, + Inverted
' See the manual under SEROUT for baud rate values
MyData = 1200 ' 1200, or whatever the data is...
MAIN:
' Read value into 'MyData' here...
SEROUT 16, MyBaud, [noparse][[/noparse]MyData, 13] ' ,13 for LineFeed
Pause 1000 ' Pause in mSec.
GOTO MAIN
--- In basicstamps@yahoogroups.com, "yellowniter" <yellowniter@y...>
If you are using the BOE, Hyperterm will be no
problem. If you have built your own board,
you must either disconnect the DTR line, or
insure a pair of .1 uF decoupling capacitors
are on the line, OR, insure DTR is inactive.
The reason is the BS2 uses DTR as a reset
signal when it is active -- and Hyperterm
will hold your BS2 in reset without these
work-arounds.
