Sending commands between stamp''s (networking)
Djr,
Hooking up two Stamps to talk to each other is easy. There is a complete
example of how to do so in the manual, downloadable at the Parallax site.
Also, search the archive for fuel injector stuff, that has been a thread
many times, and there will be a lot of information there. I have never tried
such a thing, but I hear it isn't easy.
Good Luck!
Jonathan
www.madlabs.info
Sent: Sunday, November 16, 2003 11:47 PM
Subject: [noparse][[/noparse]basicstamps] Sending commands between stamp's (networking)
> i was wondering on how to network two basic stamp 2's together, my
> project of the month is have two stamp 2's working together, one
> would be gathering snesor input data from ADC's and the other would
> be triggered and output a result from the other bs2....
> the application is a fuel injection system on a two cylender
> engine... both pistons on the crank shaft go up and down at same
> time, but the timeing on the camshaft shows that the second piston is
> 180' degree's offset of the camshaft....
> what i want to try to do is have the first basic stamp 2 perform the
> sensor data from the thottle body postion, and the intake manfiold
> presure useing the max 187 analog to digtial conveter...
> the first basic stamp 2 would contiunlusly loop over and over
> gathering data from the thottle postion and intake manifold presure..
> the second basic stamp 2 would only work as a trigger, this stamp
> would be triggered from the crank shaft and cam shaft postions. Once
> triggered it would open the injectors , corresponding to there
> locations, if both crank and cam shaft sensors were high, the stamp
> would only trigger the first injector , if the camshaft was low and
> crankshaft was high , the stamp would only open the second injector,
> and keep looling....
> And finaly hear is the question i ask, how would u communicate both
> of the stamps with there variables, there is two variables in the
> first stamp 2 that i want to send and receave on the over stamp 2...
> but the second stamp will only run its main routine from which the
> crank/cam sensors, are triggered and then run the rountine
> to "receave" the variables from the first stamp 2's sensors, after it
> would see the vaierables it would then do a lookup command from a
> table of data for those vaules...
> if anyone can help id apperiate it, i dont know if any this makes
> sense , bottom line is i want to send a variable from one stamp to
> another based on a request/trigger.
Good Luck!
Jonathan
www.madlabs.info
