Pollwait?
In below program, I noticed that if I press & hold button connected
to pin 15, then LED connected to pin 14 toggles every 1.1 sec. as
expected.
But, I also noticed that sometimes even a quick press (to bring level
of pin 15 to 0) will toggle LED.
Does anyone know what exactly the POLLWAIT 6 does? When does the
1152 msec of napping begin exactly?
'{$STAMP BS2p}
'{$PBASIC 2.5}
POLLIN 15, 0
POLLMODE 2
Loop1:
DEBUG "waste", CR
POLLWAIT 6
TOGGLE 14
'RUN 1
GOTO Loop1
END
expected.
'{$STAMP BS2p}
'{$PBASIC 2.5}
POLLIN 15, 0
POLLMODE 2
Loop1:
DEBUG "waste", CR
POLLWAIT 6
TOGGLE 14
'RUN 1
GOTO Loop1
END
question:
The POLLWAIT command is unique among the polling commands in that it
actually causes execution to halt, until a polled-input pin event
occurs. The Duration argument is similar to that of the NAP command;
using the values 0 to 7 specifies the duration of the low-power period.
After the low-power period is over, the BASIC Stamp polls the
polled-input pins and determines if any meet the desired poll state. If
no polled-input is in the desired state (as set by POLLIN command) the
BASIC Stamp goes back into low-power mode, again, for the same duration
as before. If any polled-input is in the desired state, however, the
BASIC Stamp will continue execution with the next line of code.
-- Jon Williams
-- Dallas Office
From: basicstampede [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YRw0mFnJcMd90aNuTE6C7UYfc1aDiFLBKYDgCv0LHumL1d6QAAF0KFFKngo6JL8YMet8z3L59jXKx3IgrHA]basicstampede@y...[/url
Sent: Friday, November 14, 2003 2:06 PM
Subject: [noparse][[/noparse]basicstamps] Pollwait?
expected.
'{$STAMP BS2p}
'{$PBASIC 2.5}
POLLIN 15, 0
POLLMODE 2
Loop1:
DEBUG "waste", CR
POLLWAIT 6
TOGGLE 14
'RUN 1
GOTO Loop1
END
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
>expected.
>'{$STAMP BS2p}
>'{$PBASIC 2.5}
>POLLIN 15, 0
>POLLMODE 2
>Loop1:
> DEBUG "waste", CR
> POLLWAIT 6
> TOGGLE 14
> 'RUN 1
>GOTO Loop1
>END
If you happen to press the button at the instant pollwait tests the
pin, then it will run on through and toggle pin 14 and around the
loop until it hits the pollwait 6 command again. Then it strings
together successive naps of about 1 second each, stuck at the
pollwait command, until it detects that the button is pressed again.
It only tests the input pin at the end of each one second nap, not
during the nap.
For your amusement, here is a variation that blinks the led once each
time you press or release the button. The POLLIN command is moved
inside the loop, and the POLLIN condition is based on the current
state of the input. So POLLWAIT drops through to the PULSOUT
whenever the button changes state. It is more power efficient than
looping continuously.
'{$STAMP BS2p}
'{$PBASIC 2.5}
POLLMODE 2
DO
DEBUG bin in15
POLLIN 15,~in15
POLLWAIT 4 ' 1/4 second latency
PULSOUT 14,8192
LOOP
END
-- regards,
Tracy
