Program banks — Parallax Forums
Program banks
edited 2003-11-14 20:48 in General Discussion
I have a program 0:myprog.bsp in bank 0. Inside it, I want to call
bank 1.
How do I create my program 1:myprog.bsp? I don't see any buttons on
the IDE.
Can someone please give me a step by step buttons to press to create
other program banks?
Thank you.
    edited 2003-11-14 20:17
    In a message dated 11/14/2003 3:04:17 PM Eastern Standard Time,
    basicstampede@y... writes:
    > bank 1.
    > the IDE.
    Your starting program in bank 0 is myprogram. That program name can not be
    used again.
    Go the the editor and create a new program called my2program. Put something
    in it and save it. Close that program.
    Go back to myprogram.bsp. Up at the top where it says Stamp BSP,
    myprogram.bsp - insert a comma after myprogram.bsp, then type
    my2program.bsp. Make sure you have a " } " at the end.
    Close myprogram.bsp, save it, then reopen it. Up at the top it should list
    both of your programs, and there should be tabs for each just above the editor.
    Make sure that all of your variables appear in both programs in EXACTLY the
    same order. The same goes for constants and pin assignments.
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-11-14 20:33
    I don't find this:
    My entire program says. What are you referring to about "top where
    it says Stamp BSP, myprogram.bsp"?
    '{$STAMP BS2p}
    '{$PBASIC 2.5}
    POLLIN 15, 0
    'POLLOUT 14, 1
    POLLMODE 2
    Loop1:
    DEBUG "waste", CR
    POLLWAIT 6
    TOGGLE 14
    POLLRUN 1
    GOTO Loop1
    END
    call
    > > bank 1.
    on
    > > the IDE.
    create
    can not be
    > used again.
    something
    should list
    the editor.
    EXACTLY the
    > Sid Weaver
    > W4EKQ
    > Port Richey, FL
    Just create a new program for your bank 1 code. Save it (MyProg1.BSP}.
    Then, in bank 0, change your $STAMP directive so it looks like this:
    ' {$STAMP BS2p, MyProg1.BSP}
    You may need to close and re-open the bank zero program for the hook-up
    to take place (the tabs to be updated), but the IDE will still compile
    both programs and download them to the appropriate bank.
    For more details on multi-bank programming, refer to section 3 of the
    manual, or to this N&V article:
    http://www.parallax.com/dl/docs/cols/nv/vol3/col/87.pdf
    -- Jon Williams
    -- Dallas Office
    From: basicstampede [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kNH1qf5n6VsWLv8qBSn3k4HkiHX0xF6KbQRrQLd3k5X8nJWm1nEC0Xfs2IJ6emJ2Nd-2iJMPMuJ602BX-55VuvA]basicstampede@y...[/url
    Sent: Friday, November 14, 2003 1:55 PM
    Subject: [noparse][[/noparse]basicstamps] Program banks
    bank 1.
    the IDE.
    Thank you.
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
