5 Volts serial in?
hi!
I have programmed the bs2 to work with an IPAQ for a videogame I am
designing.
A button connected to the stamp lights a row of leds also connected
to the stamp. Now if I use the 9 volts battery connected both to
ground and voltage in everything works fine, as soon as i try to use
the voltages coming out of the serial port (DTR and ground) wich
makes 5 volts the leds won't flash anylonger.
Please advices!!!
Alberto
designing.
Please advices!!!
Alberto
to use these signals to switch a transistor that in turn lights the LEDs
with the LEDs powered by an external supply (usually the same as the stamp
supply)
jim http://www.geocities.com/jimforkin2003/
From: alberto_frigo [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Fe_EUurMuNpbX54SckvVQusZTECaMvRnL5fvwycfElOt1bgYWeqCD3rGehHKy303gFLnPuL9GoeU9jcwbQ]artdavi@h...[/url
Sent: Friday, November 14, 2003 2:28 PM
Subject: [noparse][[/noparse]basicstamps] 5 Volts serial in?
hi!
designing.
Please advices!!!
Alberto
