VB for Stamp
Hihi..
I'm new to this basic stamp, but i know that Pbasic language is used
to program it. I would want to know whether visual basic can be used
to program it instead? How do I go about doing it?
Currently doing a school proj on home monitoring and automation
system. Can the basic stamp and a controller board be used?? or is it
meant for doing robotics only?
Thankz!
Thankz!
features required for embedded controllers (since the language was not
designed for embedded control) ... so the short answer is no, you cannot
program the BASIC Stamp in VB. PBASIC, however, is quite capable,
includes high-level constructs like IF-THEN-ELSE, SELECT-CASE, etc.,
that you would find in other versions of BASIC and, more importantly,
has specialized embedded commands. At the risk of editorializing,
PBASIC is slim-and-trim, VB is bloatware when in comes to micros.
Many have built all descriptions of automation systems with the various
flavors of BASIC Stamps. The BASIC Stamp can do whatever you program it
to do -- robots is just one of the popular applications of BASIC Stamps.
The limit is only your own imagination.
-- Jon Williams
-- Dallas Office
From: hysteric_kitt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T1gYTGzX0wL_97e424cV4tGOmF26IV_4BlHJxP7R9zoCK2k3kIGM7xTn2Mg7m5PmAE4nMmljqYBubwRQ175B]hysteric_kitt@h...[/url
Sent: Thursday, November 13, 2003 7:01 PM
Subject: [noparse][[/noparse]basicstamps] VB for Stamp
Hihi..
Thankz!
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
first.
Basic Stamp is a micro controller generally intended to react to an
input, do some processing and than change state of the output. The
number of inputs, processing space (software code), processing power
(variety of operators) and inputs is limited.
The desired task must fit into this hardware and software space. If
it fits - go for it, if it does not - use different hardware /
software platform. The development tool – Parallax editor – is
specifically designed to work within this hardware and software
space.
As far as using VB to code Basic Stamp – you probably could - but why?
VB was specifically developed to build code for Windows environment
not for Basic Stamp. Does someone make software to "translate"
regular VB to talk "Basic Stamp"?
I do not know, but even if they did, you will have a fancy graphical
interface that does not write the code, you do! VB IDE "desktop" can
get pretty cluttered with all the forms, dialogs etc. All this GUI
stuff obliterates the actual code.
When writing code for stamp in Parallax editor you do not have to put
up with too much fancy distraction – you see your code!
But I `ll admit, debugging in VB IDE is lot easier!
Cheers Vaclav
a very nice platform. With that, an X10
'firecracker' interface, and a few X10 modules,
you can put together a 'send only' home controller.
If you want to monitor the power line, that
takes the 'Home Run' computer interface -- I
believe it's called the CM11, also available
from X10.
The X10 approach takes care of the 110 volts
AC part of the project, and lets you concentrate
on the programming. It also allows you to control
sockets 'far away' from your BS2 or PC.
I don't work for X10, I just appreciate their
hardware. And the BS2 makes a nice controller,
in the 'Board Of Education' package.
As has been said, you can't use VB to program it.
However, the new PBasic 2.5 is quite nice.
--- In basicstamps@yahoogroups.com, "hysteric_kitt"
<hysteric_kitt@h...> wrote:
> Hihi..
used
used
it
> Thankz!
used them in alarm systems, robot control, industrial controls with sensors
and motors, laser control, marking equipment control, automation, toys, etc.
If you want something to happen in response to an input (audible,
mechanical, visual, serial data, etc.) you can use the stamp to help make
it happen. Also, use the supplied pbasic to program it. Anything else just
adds another layer of complexity to the project and produces nothing and if
you are already familiar with visual basic, you already understand how to
write the code that is necessary.
jim
http://www.geocities.com/jimforkin2003/
From: hysteric_kitt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FEYMmUcrgDIQGZf16uTI8g3ErZgy4yZdTBY18bD4CzZpOupkPi0QJZvvcoKbFw02G4N0vox39xyI-neTD7RavrZi]hysteric_kitt@h...[/url
Sent: Thursday, November 13, 2003 8:01 PM
Hihi..
Thankz!
visual basic. use mscomm event.
Jon Williams <jwilliams@p...> wrote:Visual BASIC is designed for desktop
applications and lacks a lot of
-- Jon Williams
-- Dallas Office
From: hysteric_kitt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AoTUtFQnU-NN_Y9EAoMQzy2v0A-oUocn09X-PhxCAc-m-rS6_zzmPRiOyuRhUuA-RFYzlW4w_Cm_FuzNYf-p6wIgvA]hysteric_kitt@h...[/url
Hihi..
Thankz!
abuse@p....
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
I have uploaded a file for the serial protocol demo to
the group. This vb project shows how to program a BSII
in vb. I am also now able to program the BSII using
NSBASIC CE ,nsbasic.com . It's exactly like vb.
Good Luck,
Curtis
--- Jigorok Ano <gorodaimon321@y...> wrote:
> you can communicate with your stamp through the
> serial communications port with visual basic. use
> mscomm event.
> BASIC is designed for desktop applications and lacks
> a lot of
> quite capable,
> SELECT-CASE, etc.,
> more importantly,
> editorializing,
> comes to micros.
> -- Jon Williams
> -- Dallas Office
> From: hysteric_kitt
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BPBHw2s8z20r_RSish7WZoDJI5LWucCA7Jz1Z_LBPVB-gqzs_1M_c-RCs2hc9rSh9LM25bzJCqlDOvriWL0i3vQ5]hysteric_kitt@h...[/url
> Hihi..
> language is used
> basic can be used
> automation
> be used?? or is it
> Thankz!
> Text in the Subject
> report SPAM to
> abuse@p....
> Text in the Subject and Body of the message will be
> ignored.
> Do you Yahoo!?
> removed]
> ignored.
__________________________________
Do you Yahoo!?
http://companion.yahoo.com/
