capacitor/battery question — Parallax Forums
edited 2003-11-12 17:35 in General Discussion
hey,
I'm using 'muscle wires' which require a rapid pulse of high
amperage current to contract. I'm trying to use the smallest battery
that will be able to contract the wire. I'm currently using a camera
flash battery, which can handle pulse currents high enough to
contact my muscle wire. The problem is that this flash battery is
too large and heavy for my robot. Unfortunately, most other small
batteries (coin type batteries) have a really low rating for maximum
pulse current that they can handle.
So, to get to the point, I was wondering if I could skirt this
problem by putting a capacitor in series with the muscle wire. This
way, a small battery which cannot handle a high current could take
its time charging the capacitor. Then, to contract the muscle wire,
I would just discharge the capacitor. The high current necessary to
contract the muscle wire would come from the capacitor, not the
battery (therefore a battery which cannot handle high currents would
not be harmed). Does this make any sense? Is my understanding of how
batteries work correct? Thanks for any help you could give!
    edited 2003-11-12 02:17
    > battery that will be able to contract the wire. [noparse][[/noparse]...] I was
    > wondering if I could skirt this problem by putting a capacitor
    > in series with the muscle wire. [noparse][[/noparse]...] Does this make any sense?
    > Is my understanding of how batteries work correct?
    Yes. Not only batteries, but nearly any source of electrical power you'll
    run into has a practical limit on the current you can draw for any
    significant time. Without belaboring the equations, that's what "power"
    means. You won't put the capacitor in series by the way. It has to be in
    parallel with the battery. We have a significant problem in this same regard
    when designing circuits for microprocessors. Any very fast logic has large
    jumps in current requirements when switching, and we do indeed store that
    energy in capacitors to dump into the IC on demand when the switching
    occurs.
    Someone else will have to offer you a sample circuit since I've never played
    around with muscle wire, but you have two issues that must be addressed:
    1. The circuit must protect the battery against the high inrush current when
    you start up. The capacitor will be completely discharged (or at least it
    will be in many cases), and when you close the switch it will look like a
    short circuit to the battery until it is charged. (This is not a problem,
    just a requirement for a resistor to restrain that inrush current.) If
    you're trying to use a battery type that does not tolerate sudden high
    current loads, it would be bothered by those high currents at start up, so
    you constrain them to a level the battery is designed to handle. How long
    the current must continue will depend on the next question, but if you have
    a very large capacitor the current can easily continue long enough to damage
    the battery if you do not put in a resistor.
    2. The capacitor across each muscle wire must store enough energy to heat,
    and thus contract, the muscle wire you're using. My faulty memory suggests
    it's the heat that contracts the muscle wire... The energy in any case.
    Choosing the right capacitance is one issue. Once that's done, you'll be
    able to calculate how long it will take to charge that capacitor after each
    contraction, and that will give you the cycle time on that "muscle."
    Sorry I can't give you a specific circuit, but I would expect you can find
    one on the web if no one answers here in a timely fashion.
    Gary
    edited 2003-11-12 09:03
    With a few mods the circuit Tracy suggested might work for you. I have placed
    some values that might get you started.
    Where do you source the muscle wire?
    >> Battery >----/\/\----o---/\/\
    muscle wire switch
    >> 100ohm | 1ohm
    >> ===== 100,000 uF Muscle
    wire here
    o
    >> Common
    Leroy
    Sent: Tuesday, November 11, 2003 8:23 PM
    Subject: [noparse][[/noparse]basicstamps] capacitor/battery question
    : hey,
    : I'm using 'muscle wires' which require a rapid pulse of high
    : amperage current to contract. I'm trying to use the smallest battery
    : that will be able to contract the wire. I'm currently using a camera
    : flash battery, which can handle pulse currents high enough to
    : contact my muscle wire. The problem is that this flash battery is
    : too large and heavy for my robot. Unfortunately, most other small
    : batteries (coin type batteries) have a really low rating for maximum
    : pulse current that they can handle.
    : So, to get to the point, I was wondering if I could skirt this
    : problem by putting a capacitor in series with the muscle wire. This
    : way, a small battery which cannot handle a high current could take
    : its time charging the capacitor. Then, to contract the muscle wire,
    : I would just discharge the capacitor. The high current necessary to
    : contract the muscle wire would come from the capacitor, not the
    : battery (therefore a battery which cannot handle high currents would
    : not be harmed). Does this make any sense? Is my understanding of how
    : batteries work correct? Thanks for any help you could give!
    : To UNSUBSCRIBE, just send mail to:
    : basicstamps-unsubscribe@yahoogroups.com
    : from the same email address that you subscribed. Text in the Subject and Body
    : Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-11-12 12:53
    Your idea of using a capacitor to increase short term current capability
    from your battery is valid, however, you place the capacitor across the
    battery and then discharge the capacitor through the muscle wire when you
    wish to activate it not in series with the wire.
    jim
    http://www.geocities.com/jimforkin2003/
    From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=03bHv6dwfRbMJGDdzaKKycdbAn_zpW_YezJJwS8F41STx5R-0h6zij-eNT1rRJQIHBoH58GHGAiB0Kp2]hard-on@t...[/url
    Sent: Tuesday, November 11, 2003 8:24 PM
    hey,
    I posted a file -- PulseCap.gif in the "files" section for this
    group. It is a portion of a circuit that I have used to drive high-
    voltage trigger transformers. Basically, the capacitor charges from
    the +V supply through resistor R1 and the primary of the trigger
    transformer. Note that once the capacitor is charged and not pulsed
    (DC conditions), the primary of the trigger transformer looks like a
    wire (zero ohms) to circuit common. The pulse trigger element is an
    insulated-gate bipolar transistor (IGBT). The gate looks like a FET,
    the high-current section looks like a bipolar transistor. This gives
    high switch-current capability without the base current troubles of a
    pure bipolar transistor. When the IGBT is turned on quickly, it
    pulls the end of the capacitor that was charged to +V down to zero
    volts. Since a capacitor cannot change voltage instantaneously, the
    end of the cap connected to the primary of the pulse transformer goes
    to -V, and discharges through the primary of the trigger
    transformer. The resistor provides current-limiting during the
    pulse, and also sets the recharge time.
    This circuit configuration allow for the gate of the trigger device
    to be referenced to circuit common. If the switch element
    is "floating" with respect to circuit common (as shown in your
    original circuit sketch), you cannot drive it directly from the Stamp
    outputs. This circuit configuration also requires only one active
    switch element.
    For your application, the trigger transformer could be replaced with
    the muscle-wire (I have never seen one of these, so I do not know the
    particular characteristics of this device). You would need to select
    an appropriate value of capacitance based on the resistance of the
    muscle-wire and the amount of energy that you need to provide to it.
    You would also need to select an appropriate IGBT. The one shown in
    my circuit was selected for switching a capacitor charged to
    approximately 300V.
    Good luck.
    --- In basicstamps@yahoogroups.com, "Sam" <hard-on@t...> wrote:
    > hey,
    battery
    camera
    maximum
    would
    how
