Serial Port 0.1uF 100V!! caps?? — Parallax Forums
edited 2003-11-13 03:48 in General Discussion
I have the BS2P24 Basic Stamp and I see "most" of the schematics have
two 0.1uF caps on the ATN pin (3) of the stamp. I thought it odd
that they have 0.05uF to ground and teh series/ground combination
seems "odd". If they wanted to delay the signal, a
resistor/capactior combination would be better. Maybe they want DC
isolation. I see the caps are rated at 100V!! =[noparse]:D[/noparse]
I note there are a few "odd" things like this running around in basic
stamp circuits that seem ill thought out, but get copied over a lot...
So I was wondering if anyone knew the "true story" behind the serial
port caps and exactly what they are for???
Kind thanks for your thoughts on this one that has been bugging me a
few days. I can't find the answer searching the docs...
Cheers,
Terry
    edited 2003-11-12 05:32
    Digital processor - Basic Stamp included - is a fancy marketing
    name for "random RF (radio frequency) noise generator".
    Capacitors like these (.1 uF and similar values ) are used to sent
    this noise the shortest way possible to the ground and are
    called "(RF) bypass capacitors".
    Not to worry, your stamp does not generate 100 Volts by itself.
    The signal (voltage) generated is very very low, but sometime can be
    heard even by the cheapest AM radio sitting next to the processor,
    try it!
    Voltage rating of the capacitor - 100 Volts - is generally the most
    manufatured component (size), therefore the cheapest to use.
    Vaclav
    edited 2003-11-12 15:09
    Those two caps serve an important purpose.
    The PC to BS2 link uses the ATN line to reset
    the chip in preparation of programming. This
    is wired to the PC's 'DTR' line.
    When the line goes 'active', it resets the
    chip. If you don't have those caps, then as
    long as the line is 'active' it HOLDS the chip
    in reset. Since 'active' is the default state
    of the DTR line on most serial port programs
    (Hyperterm being one), without the caps
    Hyperterm will hold the chip in reset.
    With the caps, Hyperterm holds the DTR signal
    active, but as you point out, the caps remove
    the DC component of the signal, and so the
    BS2 is allowed to come out of reset and run.
    Yes, it is 'odd', but since ATN is only used
    when reset is desired, and that doesn't happen
    very often, the AC behavior is not a problem.
    --- In basicstamps@yahoogroups.com, "ti_wrex" <ti_wrex@y...> wrote:
    > Hi,
    have
    basic
    lot...
    serial
    a
    > Cheers,
    > Terry
    Many thanks for the replies ;-)
    I now see what they are trying to do. I guess "I" would have used
    0.01uF caps and a resistor, but I guess this works fine for everyone,
    so cool! ;-))
    I checked the waveforms on pin 3 tonight during programming:
    http://team-titanium.com/%7Eti-tan/WeAreACyborg/serial1.jpg
    http://team-titanium.com/%7Eti-tan/WeAreACyborg/serial2.jpg
    Seems slow, and the negative spike is a bother, but I guess it is not
    an issue here. So I will just do the same cap thing too...
    I am adding microcontroller logic to my little battle bot ;-))
    Just a simple addition of the Basic Stamp to carry out some pre-
    defined attack maneuvers:
    http://team-titanium.com/%7Eti-tan/WeAreACyborg/ControlSchem.jpg
    http://team-titanium.com/%7Eti-tan/WeAreACyborg/ControlBoxLayout.jpg
    I hope to make the computer control thing more sophisticated over
    time, but just learning to crawl first ;-))
    I love this Basic Stamp thing!! I could never figure out the C++
    style heavy duty microcontroller coding. Having the code as a form
    of good ol' basic is a super help to those that are not sharp
    programmers 0:-)) I wrote up a little code and it seemed to work
    pretty well right off without a bunch of goofy problems :-)))
    Cheers,
    Terry
    --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
    > > Hi,
    > have
    DC
    > basic
    > lot...
    > serial
    me
    > a
    > > Cheers,
    > > Terry
