Inputs needed — Parallax Forums
Inputs needed
edited 2003-11-11 18:38 in General Discussion
You might Google for animatronics
> Any other suggestions..
    edited 2003-11-11 14:22
    You might also consider pneumatics for your power source to avoid the
    possibility of a mess in case of leaks in an enclosed area. There are
    also 1/4 scale servos which pack a pretty good punch that may work for
    you.
    The Basic Stamp is quite capable of handling the control of either
    type of system.
    --- In basicstamps@yahoogroups.com, "list" <list@o...> wrote:
    > Hi,
    > One of my friend is making Toy Dinosaurs and he required movement
    for the
    > same. Toy in the sense those sizes are 8 feet height and 10 feet
    long So
    > they r not actually toys but the are meant to kept in Park.
    > The Neck movement is required all the directions and mouth is
    vertical.
    > As per my concern I think going for Hydraulic pressure system with
    > some mechanical parts.
    > Can anyone give me inputs on this.
    > 1.Which microcontroller is best
    > 2. Which pressure system is good..
    > Thanks in Advance.
    > PS: If some of you are in these business, you can send me business
    quote as
    > well and details too....I am okay for business links too.
    edited 2003-11-11 14:46
    I would consider using pneumatic conrols. You can get air cylinders in just
    about any size and configuration you may need and controls are nothing more
    than turning on/off an air valve and maybe sensing some positions. You may
    want to look at the TFS-1 board at http://www.geocities.com/jimforkin2003/
    that can control 8 valves and sense inputs from sensors or switches. It
    supports all 24 pin stamp modules such as the bs2 and allows programming and
    debug functions on one connector and serial input on another at the same
    time if you want to control functions using a serial port from a pc. Status
    LED's on each output make for easier programming since you can see what is
    happening on the outputs at any time.
    jim
    From: leharker [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=J6r7f-FvFx8QgG34Tmq1LmmVUbFuCKGiUAZi5zJVy4tcaBtLIA6QYGHrB-ZoUmMMaqLUc3_0BYE]harker@a...[/url
    Sent: Tuesday, November 11, 2003 9:22 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Inputs needed
    you.
    type of system.
    > Hi,
    for the
    long So
    vertical.
    > Thanks in Advance.
    quote as
    One of my friend is making Toy Dinosaurs and he required movement for the
    same. Toy in the sense those sizes are 8 feet height and 10 feet long So
    The Neck movement is required all the directions and mouth is vertical.
    Thanks in Advance.
    PS: If some of you are in these business, you can send me business quote as
