EDE 1144 serial keypad encoder: anybody got it to work? — Parallax Forums
edited 2003-11-15 23:38 in General Discussion
Hi, I bought a serial 16 button keypaf encoder chip, the EDE 1144
(ref www.elabinc.com) from Jameco for $7. It looks great, good
datasheet, and should save 7 IO lines bringing the need down to just
1 line. But I can't get it to work. My alternative is to buy a
Memkey for $28 rom solutions-cubed, which has software samples.
Anybody got the ede 1144 to work? I can't eben get a keypress signal
and I have checked for all teh obvious errors.
Hope somebody can help.
Regards
Rupert
    edited 2003-11-10 10:29
    >Regards
    >Rupert
    Hi Rupert -
    Two things come to mind. First, have you set the baud rate on the EDE1144
    to the proper level (0 or low = 2400, 1 or high = 9600) which matches the
    SERIN you're using on the Stamp ? Second, are you checking the Data Valid
    signal (Pin 17 on
    the EDE1144) before attempting your SERIN ?
    HTH
    Bruce Bates
    edited 2003-11-10 18:50
    Try this
    keyVAL VAR Byte 'for keypad value
    INPUT 1 'make P1 an input
    main:
    IF IN1 = 0 THEN keypress 'check for key press.
    GOTO main
    keypress:
    SERIN 0,84,[noparse][[/noparse]keyVal]
    for keyVal 48 to 57 :
    keyVal=keyVal - 48 '# 0 to 9
    for keyVal 65 to 70:
    keyVal=keyVal - 55 '#10 to 15
    Regards
    Mohamed Refky
    >From: "strawberrypocket538" <rupert@r...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] EDE 1144 serial keypad encoder: anybody got it to
    >work?
    >Date: Mon, 10 Nov 2003 10:03:36 -0000
    >Regards
    >Rupert
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    _________________________________________________________________
    MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
    http://join.msn.com/?page=features/virus
    edited 2003-11-12 00:22
    > the EDE 1144
    > is to buy a
    > keypress signal
    Rupert,
    I have used the EDE1144 many times...I find it a
    very useful tool for connecting a keypad to the BS2.
    The only thing I had to do with mine was create a
    lookup table because the EDE1144 assumes you are using
    a keypad with a very specific arrangement of keys. It
    only took I think one or two lines of code to do it
    though.
    If you would like, tomorrow while I am at the shop
    I will post my code for scanning it using the keypad I
    purchased from B.G. Micro, which is a 16-key with 0-9
    and A-F, if memory serves...I think I followed the
    schematic exactly though that came with the chip as
    far as connection goes.
    Knight Designs
    324 West Main Street
    Montour Falls, NY 14865
    (607) 535-6777
    http://www.knightdesigns.com
    Do you Yahoo!?
    Protect your identity with Yahoo! Mail AddressGuard
    http://antispam.yahoo.com/whatsnewfree
    edited 2003-11-12 05:44
    pls send the source code.
    l'm interested..
    thanks
    Chris Savage <knight_designs@y...> wrote:
    > the EDE 1144
    > is to buy a
    > keypress signal
    Rupert,
    though.
    Knight Designs
    (607) 535-6777
    Do you Yahoo!?
    from the same email address that you subscribed. Text in the Subject and Body of
    Do you Yahoo!?
    edited 2003-11-12 15:58
    > l'm interested..
    > thanks
    Okay Rupert, here's the subroutine I used to scan the
    keypad.
    Initialization Code (This will vary on your setup):
    Start:
    dirs = $0001
    x var byte
    y var byte
    x = $30
    Calling Routine:
    Test:
    gosub KeyScan
    serout 0,16468,[noparse][[/noparse]STR y]
    goto Test
    Main Subroutine:
    KeyScan:
    if IN14 = 1 then KeyScan
    serin 15,84,[noparse][[/noparse]x]
    x = x - 48
    if x < 10 then KeyScan2
    x = x - 7
    KeyScan2:
    lookup
    x,[noparse][[/noparse]49,50,51,65,52,53,54,66,55,56,57,67,42,48,35,68],y
    return
    In this case the keypad was a 16-key unit from B.G.
    Micro using the following layout:
    1 2 3 A
    4 5 6 B
    7 8 9 C
    * 0 # D
    I noticed that the way the EDE1144 was scanning was
    not like the layout of my keypad, so I wrote the
    subroutine above to convert the numbers to the values
    for my keypad. As usual Yahoo butchered my code a
    little...In the lookup line above, the string of
    numbers in brackets should be on the same line like
    this:
    lookup x,[noparse][[/noparse]49,50,51,65.......etc.
    In the code above, I had a serial LCD display
    connected to pin 0 of the BS2. Pin 14 of the BS2 was
    connected to the EDE1144's pin 17 (Data Valid Output).
    Pin 15 of the BS2 was connected to the EDE1144's pin
    1 (Serial Output). Baud rate was 9600. If you have
    any other questions, let me know, and I will see what
    I can do. Test rig I did this with is listed on:
    www.lightlink.com/dream/chris/stamps.htm
    Knight Designs
    (607) 535-6777
    Do you Yahoo!?
    edited 2003-11-12 16:17
    --- In basicstamps@yahoogroups.com, Chris Savage
    > keypad.
    Just wanted to add, use the code that's between the
    only.
    Chris
    > Regards
    > Rupert
    Rupert,
    Were you able to get your EDE1144 working with the code I
    provided? If you have any questions on that code, feel free to ask.
