Making continuous rotation servo stop!
Hey guys,
I bought a continous rotation servo. I read the manual which said i
should use a 9 volt battery, which i did. I have a Board of
Education rev. B BS2, so i plugged the servo into pin 14 of the
servo slot (not sure if thats the name of it). I put in the code
that came with the servo. I thought the servo would stop at a
specific point with different duration values, but instead it
rotates in one direction for one range of values and in the other
direction for another range of values and i can't make it stop. Is
there a way that i can make it stop at a specific point.
I appreciate if anyone can help. Thank you!
That's the way a normal servo would work, but he _continuous rotation_ servo
you purchased is modified so that instead of the pulses controlling the
position, they control the motor's speed. If you want to move the servo arm
to a specific position, you should use a standard servo; continuous-rotation
servos are mainly for use as drive wheels.
Greg Courville
www.gee-enginuity.com
"Make it idiot-proof and somebody'll make a better idiot"
rotation, but is there any way that i can make this one stop at a
specific position. Because the standard servo, i think only has 180
degress of rotation, I need one that goes 360 and also stops. I
bought this because i thought that it would have both the stopping
ability and that 360 movement. If anyone knows any code to make
this stop at the 12, 3, 6, 9 o'clock positions, will be greatly
appreciated. Thank you!
>I understand that i made the mistake in buying the continuous
With 360 degrees as the criteria, and no linkage involved in the solution,
your best bet may be to look at a winch servo used on R/C model sailboats.
The downside to that solution may be that they travel 3 or 3.5 x 360 at
their maximum travel. I don't know if you can stop them at specific locations.
I don't believe you can due much with the servos you have, since they have had
the feedback unit removed or disabled to provide the continuous rotation.
Bruce Bates
one position,
thus it will only stop at the one spot where the feedback pulse width matches
the input's.
To do what you want would require a 360 degree pot(don't know if they make them)
or a
multiturn pot(which would still have a 5,10, or 25 turn limit).
> ability and that 360 movement. If anyone knows any code to make this
> continuous
> one stop at a
> think only has 180
> also stops. I
> both the stopping
> code to make
> be greatly
There's no mistake...You can stop a continuous
rotation servo...All you have to do if find that value
of pulses that's right in between directions. I have
done this before. One value makes it go in one
direction, and one the other, but as you move slowly
from one value toward the other, the servo runs
slower, then stops, then slowly gains speed in the
other direction.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree
the wheel to move left or right? If not, what is the best way to test
to find these values?
Mark
From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=f-k7hUXgGsJrQeb5sDYh87LlDll-pTMNbo0x1b3jX1FcNVRLB05NZ1o6UIgvi5poSS6JlryNricI2PMF7_oq]knight_designs@y...[/url
Sent: Wednesday, November 12, 2003 8:25 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Making continuous rotation servo stop!
> continuous
> one stop at a
> think only has 180
> also stops. I
> both the stopping
> code to make
> be greatly
other direction.
Knight Designs
(607) 535-6777
Do you Yahoo!?
Your use of Yahoo! Groups is subject to
the hacked servos each one can be slightly different. I suggest that you
write a program that lets you step through different pulse values while
displaying the values in the debug terminal, then put a little sticker on
each servo with its exact center value, so you can remember them easily.
Greg Courville (KG6SGY)
Sent: Tuesday, November 11, 2003 5:07 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Making continuous rotation servo stop!
> With the parallax continuous rotation servos is there a common value for
> Thanks
> Mark
> From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mT8D3sK0l3btbB8g1AsnL7loz9iqDMXElav96-vCDoRUxJh2JcqyKc7D1TKuAMbOg9BIi4l0sDE3BhL4o1RK_b4XAQ]knight_designs@y...[/url
> > continuous
> > one stop at a
> > think only has 180
> > also stops. I
> > both the stopping
> > code to make
> > be greatly
> other direction.
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
