Handling a PCF8574.
Ciao,
I'm trying to learn using a PCF8574 I2C I/O extender with my BS2p-24. But I have
some doubt about the behaviour of the I/O ports of that chip, related to its
power-on defaults and to the "quasi-bidirectional" nature of its ports, like its
manufacturer's data-sheet refers.
I need simply to connect digital inputs (like a pushbutton, as well as a signal
coming from a TTL logic) and outputs (again to a TTL logic, or a NPN-driven
relay). Could somebody give me some example in such sense?
Again, has the BS2p-24 any limitations about the number of I2C devices connected
to the same port?
Thanks in advance,
Alberto.
to the same port?
Thanks in advance,
Alberto.
I'm using the PCF8574 in de C-programmed PC application, not (yet) in a
Stamp setting.
Each I/O of the 8574 is software programmable as input or as output.
I suggest you retrieve the datasheet from the Philips website, this will
make things clear to you.
Klaus
PS I do use the PCF8591 analog input/output chip in a Stamp BS2 setting.
First I was a bit confused on how to connect and program the chip but once
it is working things are quite straightforward.
Oorspronkelijk bericht
Van: Alberto Calderara [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=umlF47cT4WqOv1onPVpagMdm-0QLSvsaDXwGkbmMRUhew2wqfB2x05GzrIedW0y3I_E0TqhgvhHUBFY-NOOc_XZIgzQC]albertocalderara@t...[/url
Verzonden: zondag 9 november 2003 22:08
Aan: Basicstamps group
Onderwerp: [noparse][[/noparse]basicstamps] Handling a PCF8574.
Ciao,
have some doubt about the behaviour of the I/O ports of that chip, related
to its power-on defaults and to the "quasi-bidirectional" nature of its
ports, like its manufacturer's data-sheet refers.
signal coming from a TTL logic) and outputs (again to a TTL logic, or a
NPN-driven relay). Could somebody give me some example in such sense?
connected to the same port?
Thanks in advance,
Alberto.
