C++ help with the BS2
Archiver
I am familiar with C++ and i want to interface the computer with the BS2 via
parallel port. i know it is possible to write bits to the parallel port and
have the stamp interpret it as a high and low signal. the only thing though
is that i dont know how to access the parallel port. what instruction. also
is anyone familiar with the Game counter strike? the reason for this
adventure is that i want to create a rumble vest. if i could get the game to
output to the parallel port i can get the stamp to trigger a vibrating motor
as if i was in the game. i already emailed Valve the creators of the game
and they dont want to talk to me. any help would be appreciated. thanks
GMDII
GMDII
Al Williams
AWC
* New: 3 years of Stamp Project of the Month
http://www.al-williams.com/sombook.htm
> From: Gary Denison [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CPLX-4aMG9IYCW2QA-wBtdBW75063QJPsIHx5tpEo32Jz-ldWGUOXJdzsukc2hFaDqRC6Q]gdii@c...[/url
> Sent: Sunday, November 09, 2003 2:35 PM
> Subject: [noparse][[/noparse]basicstamps] C++ help with the BS2
> with the BS2 via parallel port. i know it is possible to
> write bits to the parallel port and have the stamp interpret
> it as a high and low signal. the only thing though is that i
> also is anyone familiar with the Game counter strike? the
> reason for this adventure is that i want to create a rumble
> vest. if i could get the game to output to the parallel port
> i can get the stamp to trigger a vibrating motor as if i was
> appreciated. thanks GMDII
> from the same email address that you subscribed. Text in the
He wrote a book on the Printer port...I've done some of the projects...Most of
his code is C So if you could get CS to send commands to your exe...then you
could skip the stamp and just use the 8 data lines for your vest. They are TTL
so you can't run the relays directly from them...well...unless you get Solid
State ones [noparse]:)[/noparse]
I'd look to the Mod community....Valve won't work with you like the people who
modify games will.
I'd think if you could get say a separate audio channel going with different
length tones for each spot you where hit you could have the Stamp monitor that
output and skip the LPT port and EXE all together. Once again....the Mod
community would be your best bet....
As a side note....knowing where you got shot would be very cool!!!
Good luck with your project....if you need help on the PC side I have the
examples that Anderson's book comes with [noparse]:)[/noparse]
Tim
>>> gdii@c... 11/09/03 02:34PM >>>
GMDII
from the same email address that you subscribed. Text in the Subject and Body
At 01:33 PM 11/11/2003 -0500, you wrote:
>http://www.phanderson.com
>projects...Most of his code is C So if you could get CS to send commands
>to your exe...then you could skip the stamp and just use the 8 data lines
>for your vest. They are TTL so you can't run the relays directly from
>them...well...unless you get Solid State ones [noparse]:)[/noparse]
>who modify games will.
>different length tones for each spot you where hit you could have the
>Stamp monitor that output and skip the LPT port and EXE all
>together. Once again....the Mod community would be your best bet....
>Tim
>GMDII
