Slightly OT: protecting inputs from negative voltage?
Archiver
Hello!
I'm working on a music synthesizer project that my use a basic
stamp. Some of the I/O lines of the basic stamp are going to be
configured as inputs. Any myriad of voltages may be hooked up to
that input from analog synths.. from -15v to 15v. I have used a
zener clamp circuit to limit the voltage to +5 volts. However, my
electronics skills are, well, not so great.
Q: Should I be concerned about negative voltage appearing on my basic
stamp inputs? And, if so, could someone point me to a simple
schematic of a circuit which will clip out the negative voltages?
Q: If I have some I/O lines that are set as outputs, there's still a
possibility that someone will hook up a positive voltage to that
input. That should do nothing, right? :-) I don't need to worry
about that, do I? My trivial amounts of electronics theory suggests
that hooking a positive to a positive doesn't do anything.
Thanks! Are there any good books that discuss protecting
microcontroller inputs?
- Bret
- Bret
You can use a simple silicon switching diode to prevent negative voltage
from getting to the input pin. Connect it so that the end with the stripe is
connected to the stamp pin and the other end is connected to your signal
source. Note, however, that this will drop the voltage coming in by about a
volt.
As for the output pins...
There are three states a stamp pin can be at: high (around 5 volts), low
(around 0 volts), or high-impedance (think of it as not connected to
anything).
When a pin is in input mode, it will be at high-impedance - it will not
drive any voltage. When a pin is in output mode, it will be held either low
or high. If it is low and you connect a positive voltage to it, you will
basically have a short circuit (you are effectively connecting your positive
voltage to ground through the stamp), and soon a dead pin. Even if the
voltage you connect is around the same as that on the stamp pin, any small
difference in voltages between the pin and whatever you connect will cause
current to flow. I suggest you use a current-limiting resistor (250 ohms or
more) on any pins where this situation may occur.
Greg Courville (KG6SGY)
www.gee-enginuity.com
"Make it idiot-proof and somebody'll make a better idiot"
Sent: Saturday, November 08, 2003 5:18 PM
Subject: [noparse][[/noparse]basicstamps] Slightly OT: protecting inputs from negative voltage?
> Hello!
> - Bret
1. If you have a pin configured as an Output,
and it is holding 0 volts on the Output, and
another device tries to put +5 on the pin,
then yes, you have a problem which can burn
out the Stamp pin. Your assumption that
hooking up a positive to a positive is OK
is NOT correct.
2. If you put a negative voltage on a Stamp
pin, there are built-in diodes which protect
the stamp -- as long as you limit the current.
The solution to both of these problems is
similar.
For the 'multiple-output' situation, putting
a 220 ohm resistor in series with the Output
pin will protect it from over-current.
For the 'negative voltage' problem, a
22 KOhm resistor in series will drop the current
to the point the internal diode will not be
harmed. This is done all the time to let
the Stamp receive RS-232 (-15 Volt) voltages
without damage.
--- In basicstamps@yahoogroups.com, "c45a6" <clone45@h...> wrote:
> Hello!
basic
a
suggests
> - Bret
