NTC Thermistor
Hello
Has anyone done any projects which involved using a thermistor for
temperature measurements
Any pointers would do
Isaac
Isaac
I have built a fairly accurate (+/- 0.2 degrees C absolute) NTC-thermometer
using the command RCTIME.
The secret for my sensor was to linearize the curved relationship between
resistance and temperature. I did this linearization by cutting the curve
into pieces and then fit each each piece by a short straight line.
See code below to get an idea how this linearization works. For this
calculation you will need the resistance of the sensor at given temperatures
Tcal plus the slope of its curve.
Regards.
Klaus
' NTC == miniature sensor, used for fever-thermometers
' Ts = Cx - RT/Cy Ts: Temperature of sensor * 10
' RT: output of RCTIME
' Cx = T_cal + R_cal/(dR/dT)_cal cal: 10,15,20,25 degree C
' Cy = K*(dR/dT)_cal (dR/dT): slope of curve at this point
' K = 29,57 K: system constant for BS2 and cap = 0.47 uF
'{$STAMP BS2}
OUTPUT 15
Ts VAR WORD
RT VAR WORD
Main:
OUT15 = 1 'just a flashing led to indicate the system is running
HIGH 12
PAUSE 10
RCTIME 12, 1, RT 'here the resistance of the sensor is measured
OUT15 = 0
' below are the four straight lines for linearization
Ts = 479 - (RT/107)
IF Ts>225 THEN Label1
Ts = 420 - (RT/139)
IF Ts>175 THEN Label1
Ts = 367 - (RT/177)
IF Ts>125 THEN Label1
Ts = 306 - (RT/231)
Label1:
' display output with decimal point, ie 19.7
DEBUG CLS, DEC Ts/10, ".", DEC1 Ts
PAUSE 440
GOTO Main
Oorspronkelijk bericht
Van: isaac_aiyanyo [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0g93u_LQinISEjdhAFUABcYS1toFqPKtQXN9aAuKUFVUN1AdUjw_PbjLX762qmmwJxQ65iKPYv6bSM1dlaQR9tU8]isaac.aiyanyo@n...[/url
Verzonden: zaterdag 8 november 2003 23:12
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] NTC Thermistor
Hello
Isaac
Thanks for your reply you have given me hope as i was thinking it would be
almost impossible to do
the thermistor i am using have got 3k @ 25 degees C
i want to use the range from -20 to 80 degees C using the command RCTIME
and need at most +/- 0.5degrees C
accuracy.
For my range does this mean i have to do say _20,-15,-10,-5,0
then do say 5,10,15,20,25 etc
temperatures
On my data sheet i have got the resistance of the thermistor given over the
entire range example
at -20 degees C resistance is 19.41 K
at -15 degees C resistance is 19.29K
at -10 degees C resistance is 19.01K
at -5 degees C resistance is 18.79K
i got a bit lost with the maths trying to figure out how this would be
placed in the formula here could you kindly break it down for me RT is the
result of the command RCTIME thats clear
Where would i get T_cal from and also what values would i use for (dR/dT)
Could you please expand on this using the values above
Thanks for Your Time
Very Much appreciated
Isaac
