Ncd operator
Hi all
Trying to use and do the impossible I think part of program below I think I have
total gone na na
HOW CAN I MAKE AN ARRAY Byte size but in relation to a word.
Tracy has stuff on his web that I have read and kind of understand but is it
allowed and or possible to do below
'{$STAMP BS2}
CHKLV VAR W1
CHK VAR Byte(20)
BEGINNING:
STARTB:
PULSIN 0,1, CHKLV 'wait for right pulse above 0 below 4
'IF CHKLV> = 0 AND CHKLV< =4 THEN STARTB
PULSIN 0,1, CHK(NCD(0)) ' capture a wordsized increasing or decreasing
value 0 - 3000 in Pulsin value debug to a PC screen through a looping pulsin
word size program
REPEAT PULSINS DOWN TO
PULSIN 0,1, CHK(NCD(19))
do MATH stuff here with results then back to beginning
Rob
This email is confidential and may also be privilege.
If you are not the intended recipient, please notify us immediately.
You should not copy or use it for any purpose, nor disclose it's contents to any
other person.
total gone na na
'{$STAMP BS2}
CHKLV VAR W1
CHK VAR Byte(20)
BEGINNING:
STARTB:
word size program
Rob
other person.
coming from, maybe we could provide more useful help. I'll put some
comments in your code...
>Hi all
>think I have total gone na na
>but is it allowed and or possible to do below
>'{$STAMP BS2}
>CHKLV VAR W1
>CHK VAR Byte(20)
>BEGINNING:
>STARTB:
If you de-comment that if, you will come here for all pulses >4.
It could be written, "IF CHKLV <5 THEN STARTB". The Stamp IF
statement considers all numbers positive, so there is no need to test
for >=0.
>decreasing value 0 - 3000 in Pulsin value debug to a PC screen
>through a looping pulsin word size program
This statement will always put the value in array element CHK(0).
The value of NCD (0) is a constant, always zero.
Here is a table of NCD X versus X:
X NCD X
0 0
1 1
2 2
3 2
4 3
5 3
6 3
7 3
8 4
9 4
10 4
11 4
12 4
13 4
14 4
15 4
16 5
17 5
18 5
19 5
Does that help you understand how NCD works? If you want to capture
the word value and put the "compressed" value in your array, you
would do something like the following:
FOR I=0 to 19
PULSIN 0,1,x
IF x>4 THEN
y=NCD x MIN 1 -1 ' this is a value from 0--15
y=y<<4+((x - DCD y)>>(y MIN 4 - 4)) ' bitlog value from 0-255
CHK(I) = y ' put bitlog x into array
ENDIF
NEXT
' do processing here
For example, if the pulse value is x=3000, then the value put into
the array will be 183. That corresponds to a log base 2 value of
183/16 = 11.44 compared to the true value log2(3000)=11.551
-- Tracy Allen
http://www.emesystems.com
>Thanks
>Rob
