help with a controller for a windgenerator powered heater — Parallax Forums
edited 2003-11-11 11:13 in General Discussion
Hello,
I am looking for a controller for a small wall heater which will be
powered by a windgenerator. The output from the generator will be
around 0-100v dc at a maximum continuous of around 500w. When the
generator starts turning the voltage will begin to rise so the
controller will be required to gradually increase the load as it
gathers speed and decrease the load when it slows down. I am pretty
much a beginner at electronics so any help would be much appreciated.
Regards
    edited 2003-11-07 14:38
    At 10:41 AM 11/7/03 +0000, hallmgr wrote:
    >Hello,
    >Regards
    >If the heater has multiple settings (high, medium, low), you may be able
    >to tap
    >into that with relays. Perhpas you could describe the heater, or provide a
    >link ?
    >Bruce Bates
    edited 2003-11-07 15:47
    I dont have a specific heater in mind for the job but I will probably just use a
    110v one. I am not sure what controls it will have.
    From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=a2TTzMLoYHGZf41NCuKjDrN8iir_t0qxKTTfH0X6b_z1Bua0vEjUyBrzB1aPcS7UWQHP6rM7FsbcZdLo]bvbates@u...[/url
    Sent: 07 November 2003 14:38
    Subject: Re: [noparse][[/noparse]basicstamps] help with a controller for a windgenerator
    powered heater
    >Hello,
    >Regards
    >to tap
    >link ?
    >Bruce Bates
    from the same email address that you subscribed. Text in the Subject and Body
    edited 2003-11-07 15:49
    --- In basicstamps@yahoogroups.com, "hallmgr" <HallMG@b...> wrote:
    > Hello,
    pretty
    appreciated.
    > Regards
    I'm not sure I follow.
    as the wind speed changes, the heater increases ? that would make
    heat dependant on wind speed ?
    are you sure the voltage from the generator is not contorlled so you
    get 100VAC at any speed above "x" but the available amps changes with
    speed ?
    Dave
    edited 2003-11-07 15:56
    You need absolutely nothing.
    When the voltage rises, the current rises accordingly.
    You have to verify that a typhon will not burn the heater.
    Regards
    ECO
    Sent: Friday, November 07, 2003 11:41 AM
    Subject: [noparse][[/noparse]basicstamps] help with a controller for a windgenerator powered heater
    > Hello,
    > Regards
    edited 2003-11-07 16:41
    What I am looking for is some kind of controller which will allow the
    windgenerator to get up to speed before connecting the load. Connecting all the
    load in one go would be too much for the generator, it would probably stall, so
    some kind of gradual loading would be required as the generator increases speed
    to maintain optimum loading. The generator produces unregulated dc from 0 to
    around 100v so so I thought the controller would be able to monitor this to
    control the loading? All I require from the heater is for it to deliver what
    heat it can depending on the power from the wind, I dont need any specific heat
    settings other than an emergency cut out. The generator has to be kept loaded
    when it is running or it will overspeed.
    Melvin.
    From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SmthpgzJJQu6o2gJtyKDi-14u5jUTfjD0wavUurkNIngRiKh9KSyTT7pQbi0rCLeQD_cVrzeknZJ]davemucha@j...[/url
    Sent: 07 November 2003 15:49
    Subject: [noparse][[/noparse]basicstamps] Re: help with a controller for a windgenerator
    powered heater
    > Hello,
    pretty
    appreciated.
    > Regards
    speed ?
    Dave
    edited 2003-11-07 18:21
    --- In basicstamps@yahoogroups.com, "Hall, Melvin GR" <HallMG@b...>
    the windgenerator to get up to speed before connecting the load.
    Connecting all the load in one go would be too much for the
    generator, it would probably stall, so some kind of gradual loading
    would be required as the generator increases speed to maintain
    this to control the loading? All I require from the heater is for
    it to deliver what heat it can depending on the power from the wind,
    I dont need any specific heat settings other than an emergency cut
    out. The generator has to be kept loaded when it is running or it
    will overspeed.
    > Melvin.
    The heater is a resistive load. as the generator increases above
    zero, the get some voltage and some current. do ohms law on what you
    can find on the spec sheet for the unit.
    the heater will not prevent the generator from turning as it cannot
    get 10 amps when only 1/10th amp is being generated.
    It seems like you have the easist setup. the heater is a resistive
    load and will just follow the curve of voltage and amps as the
    generator changes speed.
    Storage Batteries on the other hand are much more sensitive to a very
    narrow voltage band and require electronics.
    If you are just looking for a project, considder a voltage monitor
    that turns on different heaters at different voltages. maybe even a
    fan will be turned at some voltage and a voltage regulation circuit
    to keep the fan voltage constant.
    Dave
    edited 2003-11-10 12:44
    I would prefer to have some kind of voltage monitoring circuit to switch the
    heater on when the generator gets going. How would I go about obtaining one?
    Melvin.
    From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oWXL15Ql0lFHib6GH_LT6l-3_uPwVtpTo3y7LgCizURsa-va7BhF4NM5RyxvUesvME_4TsvVko6slw]davemucha@j...[/url
    Sent: 07 November 2003 18:21
    powered heater
    will overspeed.
    > Melvin.
    Dave
    edited 2003-11-10 16:24
    I will need some kind of controller that will only connect the load to the
    generator when it gets up to speed so it wont stall.
    Melvin.
    From: ECO [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oEO5Ss0qbmsMSp4PSoLEAwFmJYRnY701N1ffqVV7cG1PqaT3cdbg7BWr_kH_CVbSfOs0ALdoc0Fr]ecourt@b...[/url
    Sent: 07 November 2003 15:56
    powered heater
    Regards
    ECO
    > Hello,
    > Regards
    edited 2003-11-10 18:05
    Melvin,
    If I understand correctly, you want to turn on a heater when there is enough
    current to run it, and change the setting on the heater from low to high
    depending on the current available.
    I assume that the heater has switches to set the heat output. A relay could
    be used to switch between them. Have the Stamp check the input voltage, and
    if it's high enough, then try the heater on low. If the voltage remains OK,
    switch to high. If it drops, cut out the heater. You will need to set the
    parameters to avoid too rapid switching on and off. Does the heater have a
    thermostat? If not, you could easily add a temp. sensor and control the room
    temp. This would allow you to use the current being generated for other
    things once the room is warm enough.
    Another option would be to get the windspeed from the generator. You could
    use a NIB magnet and a Hall effect sensor. Then you could turn the system on
    when the wind gets above X miles per hour.
    Hope this helps,
    Jonathan
    www.madlabs.info
    Sent: Monday, November 10, 2003 8:24 AM
    Subject: RE: [noparse][[/noparse]basicstamps] help with a controller for a windgenerator
    powered heater
    > Melvin.
    > From: ECO [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tSYn30jN-tlpdPuX-m5g2LY6FZ2tuiV-DnVsGD58XUdRUOD0sZHzOC5qxK2hRFvWoZ5ElBdtNKXUNOARas8]ecourt@b...[/url
    > powered heater
    > Regards
    > ECO
    > From: "hallmgr" <HallMG@b...>
    heater
    > > Hello,
    > > Regards
    edited 2003-11-10 18:19
    >Melvin.
    Yes, you need a controller to let the rotor get up to speed before any
    substantial load is connected or the blades will stall.
    Does your mill use an alternator or a generator?
    If it's an alternator you can look at the output frequency to determine the
    speed. Disconnect all load below a certain speed, then connect more
    load in stages as the RPM increases, or PWM the output to provide
    "load matching" to the speed.
    A generator might need some kind of magnetic or optical sensing system
    on the rotating parts to count RPM.
    Available power goes up as the cube of wind speed, so make sure you
    can provide plenty of load to keep from over-speeding in severe weather.
    Or use a furling system to turn it out of the wind when things get scary...
    Steve
    edited 2003-11-10 18:29
    Steve,
    Good point about the over-speeding. Perhaps a water heater element or
    similar could be switched on by the Stamp to prevent this.
    Jonathan
    Sent: Monday, November 10, 2003 10:19 AM
    powered heater
    the
    > >Melvin.
    the
    scary...
    > Steve
    edited 2003-11-11 01:28
    to the generator when it gets up to speed so it wont stall.
    > Melvin.
    There are more than a few ways to make a cheap ADC.
    a 555 and a BS2 can work together as a cheap ADC.
    I have not tried an RC to see how it would work as the voltage
    changes, but there is no reason why you can't make some very simple
    and low cost voltage monitoring and then as you pass each threshold,
    you can open or close different relays.
    if you get a milti channel ADC, you can also put in a shunt and
    measure the current the unit is putting out and control your load
    that way too. the wire itself can be used. I'm not sure of your
    amps, but a few feet of wire has a measurable resistance and would
    change as the voltage changes yielding an amp reading.
    There was a link to resistance per foot, I am guessing someone on
    here posted a link some time ago. ?
    do you have a link to the generator ?
    It would help if we had some of the parts to he puzzle.
    Dave
    edited 2003-11-11 02:23
    10 GA solid wire has a resistance of just a tiny bit over 0.001 ohms per foot
    at room temperature, which conveniently gives 1 millivolt per amp on a
    voltmeter...
    Here's a pair of 10 GA shunts I built on one board...
    http://www.weirdstuffwemake.com/altenergy/misc/10GAshunt.jpg
    Cheers,
    Steve
    The generator is currently under constuction so all my numbers are theoretical
    but I will thoroughly test the alternator before putting it to use. The
    alternator has ten coils which are arranged in pairs to give a five phase
    output. This is rectified at the top of the windmill tower to give a course dc
    which is carried down the pole to the ground using a pos and neg cable.
    At maximum continuous running speed the voltage is likely to be around 70v,
    current of around 10A
    and so power of around 700w. I am not sure what you mean by the terms 555,
    bs2, adc and shunt, please could you tell me more about them. If the controller
    you suggest can switch on relays at various voltage thresholds then the best
    idea may be to use several small elements, say 100w each and have them switching
    on one at a time.
    Melvin
    From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Nt0yevUimBck4wQJhQfHoWDnirU0iosDOMTwElCdkHABJzssCCsxOKUtflm2Inymihj0Bgpyfs-8J3Ef]davemucha@j...[/url
    Sent: 11 November 2003 01:28
    powered heater
    > Melvin.
    Dave
