resistor question regarding midi out from stamp
Archiver
Out of curiosity, no matter what the code is, would using a 240ohm
resistor where a 220 ohm resistor should be in regards to pin 4 on the
female midi interface, and a 200 ohm resistor where a 220ohm resistor
should be in regards to pin 5 on the female midi connection actually
cause the whole thing to not work at all? I was merely working with
what was available, I still figured I'd get something out of it... was
I grossly mistaken? thanks.
ry
--- In basicstamps@yahoogroups.com, "r_couldrey" <r_couldrey@y...>
wrote:
> okie dokie, currently have a bunch of wires all over my desk, and
have
> lost several thousand strands of hair in frustration over this midi
> setup. Scratched the idea of 15 potentiometers due to cost (about
> 5$CAN per POT and plastic knob, !!!!) Trying to get a flex sensor on
a
> stamp to be recognized as a midi controller within Reason, and
cannot
> for the life of me get it working. I've tried altering the
parameters
> within the code, but it isn't sending out any midi through pin 0
from
> the flex sensor on pin 1. I'm certain I have the hardware set up
> correctly, but I'm pretty uncertain about how I've butchered this
> code. Reason itself isn't detecting any midi information that I can
> see. If I've really blatantly messed anything up, it'd be great to
> know, as I can't figure this out at all.
> a great many thanks in advance for any help. With any l,uck, I won't
> short circuit my Quattro in the meantime...
> ryan
> 'constants, shouldn't change these
> midibaudmode CON 32780 '31.25kb, 8n1, non-inverted, open collector
> 'for 14-bit controllers - controller 32 is lsb of controller 0, etc.
> controllerLSBoffset CON 32
> 'MIDI status bytes:
> controller CON %10110000 + 0
> noteon CON %10010000 + 0
> pitchbend CON %11100000 + 0
> 'declare variables
> value VAR Word 'holds the 16-bit value read from the pot
> pin VAR Nib 'which pin/pot we are reading at the moment
> statusbyte VAR Byte 'MIDI status; controller, noteon, or
pitchbend
> data1 VAR Byte 'first data byte, eg. controller or note
> number
> data2 VAR Byte 'second MIDI data byte, eg. value or
velocity
> 'user configuration - adjust these to suit you
> 'DANGER - check your circuitry and configure pins accordingly!!
> 'set unused pins to outputs
> DIRS = %1111111111111111 'all outs
> OUTS = %0000000000000000 'all low
> midichannel CON 1 'MIDI transmit channel
> midioutpin CON 0 'pin connected to MIDI out connector
> 'check the MIDI spec for a list of controller numbers you can use
> controlleroffset CON 0 'add to pot's pin # to get MIDI controller #
> hipot CON 1 'highest pin with a pot to measure
> lowpot CON 1 'lowest pin with a pot to measure
> doit:
> DEBUG HOME
> FOR pin = lowpot TO hipot
> 'read the value of the pot
> HIGH 1
> PAUSE 0
> RCTIME 1, 1, value
> DEBUG value, DEC pin, " reads ", DEC value, CR
> value = value >> 1 'drop the least significant bit
> 'send most significant 7 bits as continuous controller msg
> statusbyte = controller 'sending controller message
> data1 = pin + controlleroffset 'controller #
> data2 = value.HIGHBYTE
> SEROUT data1, data2,[noparse][[/noparse]statusbyte, data1, data2]
> 'uncomment this section to send 14-bit controller data
> 'send least significant 7 bits
> data1 = data1 + controllerLSBoffset
> data2 = value.LOWBYTE
> data2 = data2 >> 1 'convert to 7 bits
> 'use running status byte (can leave it out if unchanged)
> SEROUT data1, data2, [noparse][[/noparse]data1, data2]
> NEXT
> GOTO doit
ry
have
a
cannot
parameters
from
> ryan
> 'MIDI status bytes:
> 'declare variables
pitchbend
> number
velocity
> doit:
> DEBUG HOME
> HIGH 1
> PAUSE 0
> RCTIME 1, 1, value
> NEXT
> GOTO doit
the
resistor
actually
was
> ry
> have
midi
on
> a
> cannot
> parameters
> from
can
won't
> > ryan
collector
etc.
> > 'MIDI status bytes:
> > 'declare variables
moment
> pitchbend
> > number
> velocity
controller #
> > doit:
> > DEBUG HOME
> > HIGH 1
> > PAUSE 0
> > RCTIME 1, 1, value
> > NEXT
> > GOTO doit
ragged end of specifications. It's simply a current limiter for an
opto-isolator.
-- Jon Williams
-- Dallas Office
From: r_couldrey [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=D1J0DPVNlC06iF3FsUw33DdR53OeTMMD1JEn2RhCcY-3nKxqrngVo5IV6tM3AFuWs06LzYtC5sTuhg]r_couldrey@y...[/url
Sent: Thursday, November 06, 2003 2:11 PM
Subject: [noparse][[/noparse]basicstamps] resistor question regarding midi out from stamp
ry
have
a
cannot
parameters
from
> ryan
> controllerLSBoffset CON 32 'MIDI status bytes:
> 'declare variables
pitchbend
> number
velocity
> 'DANGER - check your circuitry and configure pins accordingly!! 'set
> unused pins to outputs DIRS = %1111111111111111 'all outs
> doit:
> DEBUG HOME
> HIGH 1
> PAUSE 0
> RCTIME 1, 1, value
> NEXT
> GOTO doit
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
