broken stamp I/O pin - chip sockets
--- In basicstamps@yahoogroups.com, "Beau Schwabe" <bschwabe@a...>
wrote:
> At 09:30 PM 11/3/03 +0000, you wrote:
> >--- In basicstamps@yahoogroups.com, Gary Denison <gdii@c...> wrote:
> > > i have Broken I/O pin 7 on my Bs2 what do i do for repairs? will
> >parallax
> > > fix it? thanks for any help Gary D
> >Depending on how is it broken, you could use a chip carrier or chip
> >socket. stick a resistor lead in the matching socket and then
stick
> >the Stamp in. then solder the lead to the stamp.
> >that way, all the ruture abuse will be on the chips socket.
> >Dave
> Dave,
> I think we're on the same wavelength here. I had mentioned
> the use of a wire-wrap socket primarily for the length (cut
> as desired) and durability of the 'pins' relative to just a
> standard IC socket. Forget for the moment that you can
> wire-wrap to the socket and just use it as a durable conduit
> for the Stamp.
> -Beau Schwabe
YES !
NEWZED has done some really great projects with me (if you need help
on a budget), anyway... on a board he did for me, he insisted on the
machined sockets, not the really cheap sheetmetal ones.
The gold machined ones are less than a buck, the sheet metal ones
less than a dime. HUGE difference in quality.
For this broken pin use, the machined pin style is well worth the
extra quarters.
I have not used the wire wrap style and assumed (yeah, I know) that
they had thicker and square pins and would not fit into a socket
easily.
Dave
> >parallax
stick
> >Dave
> Dave,
> for the Stamp.
> -Beau Schwabe
YES !
extra quarters.
easily.
Dave
