Conver Scratch pad-string to numeric value on Bs2p
Archiver
I use a Pak6a to get read a keyboard.
The key is stored by:
Store:
Put Adr,KeyIn
Adr=Adr+1 ' So next key is stored on the next adress.
Return
When I need to convert from string to numeric value:
Convert:
Number=0
For I=0 to Adr-1 '-1 cause adr is +1 every time key is stored
GET I,KeyIn 'Get digit from field
Number = Number + (KeyIn - "0") 'convert add into value
Number = Number * 10 ' shift result digits left
Next
Debug Dec number
But the convertion don't work.
Is there a better way to convert string to numbers?
Stein.
Store:
Put Adr,KeyIn
Return
Convert:
Number=0
Next
Debug Dec number
Stein.
and BS2pe.
I wonder if your convesion issue has to do with the order your keys are entered.
Let's say, for example you enter the number 325. I would assume, based on your
code that it would appear in the Scratcpad as follows:
0 : 3
1 : 2
2 : 5
If this is the case, you need to to update your convesion like this:
Convert_Num:
number = 0
FOR idx = 0 TO (addr - 1)
number = number * 10
GET idx, keyIn
number = number + (keyIn - "0")
NEXT
The problem is that you're shifting "late" which will cause the 1's digit to be
multiplied by 10 unnecessarily.
-- Jon Williams
-- Dallas Office
It's working exactly as you wrote.
eeee....I did not use "store" in my code.
Just made one up when I made the massage.
By the way....will the Scratch pad Ram be worn out like the Eeprom?
Stein.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Be careful using STORE as a label since this is a PBASIC keyword
for the BS2p and BS2pe.
keys are entered. Let's say, for example you enter the number 325.
I would assume, based on your code that it would appear in the
> 0 : 3
> 1 : 2
> 2 : 5
this:
> Convert_Num:
> number = 0
> GET idx, keyIn
> NEXT
1's digit to be multiplied by 10 unnecessarily.
> -- Jon Williams
> -- Dallas Office
> From:
-- Jon Williams
-- Parallax
