CU40046MCPB-S VFD disply
Hi All,
I am thinking of buying a CU40046MCPB-S VFD display. Has anyone used this or
a similar unit? It is a 4X40, which I assume is actually two 2X40s together.
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
It's a 4line*40 parallel LCD display with backlight.
Go to:
http://www.allcorp.com/
You can't find a cheaper big display.
The BS2p has inbuilt command to send directly to the Display.
Input E1 and E2 are to address the upper or lower 2 lines, as you
discovered correctly, they are programmed as two different displays.
Stein.
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@p...> wrote:
> Hi All,
used this or
together.
> Thanks,
> Jonathan
> www.madlabs.info
IEE. The part number is 03602-100-05420. It is a 4 X 20 with both aserial or
parallel input. The parallel is similar to the 8 bit format fro the Hitachi
controller used in LCDs. The VFDs are quite costly but can't be beat for
illumination and viewing angle.
azeasi
Nice display, I ordered one. But, for my current project, I really want to
use a VFD.
Jonathan
www.madlabs.info
are backlit or not.
Yup on them being electrically two separate displays, and the pin-out is
different as well.
As far as VFD's, they are good and crisp, but suck power like nobody's
business. Don't expect to use a large VFD on a battery-powered device.
> I'm using a Seiko L4044B1J.
> Go to:
> used this or
> together.
Is the display any different to use than an LCD? The display I am looking at
is serial or parallel, and I was planning on using the serial. I know that
one has to deal with it as two seperate displays, but I have never done it.
Any tips or codes snips would be welcome.
Jonathan
www.madlabs.info
Sent: Monday, November 03, 2003 3:51 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: CU40046MCPB-S VFD disply
> The LCD display is very different from the VFD. I am using a similar VFD
from
Hitachi
> azeasi
It's not for a battery powered application, it's for my weather station, so
thats OK. Ever used one?
Jonathan
www.madlabs.info
> > Go to:
> > used this or
> > together.
