small MIDI question
Archiver
http://www.booyaka.com/~al/audio/projects/diy_midi_controllers.htm
Simple question for anyone who may know the answer. In the section
where it discusses Interfacing to MIDI, can anyone tell me whther or
not the midi socket diagram illustrating which pins go where is a view
of the male or female side of a midi cable? Many thanks.
ryan
ryan
-- Jon Williams
-- Parallax
From: r_couldrey [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wmB5SWkl5fmN6RdfRkGtridE7GYIf-s902erUoqStiEUBBtgHpCzcue6U9MEMGQi0H-T7rYkwCpeVlzghQ]r_couldrey@y...[/url
Sent: Sunday, November 02, 2003 12:26 PM
Subject: [noparse][[/noparse]basicstamps] small MIDI question
ryan
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
isn't fast enough to do MIDI which is something like 31k baud. You'll
need the sx one or a PIC, I believe . . .
> view
> ryan
__________________________________
Do you Yahoo!?
Exclusive Video Premiere - Britney Spears
http://launch.yahoo.com/promos/britneyspears/
http://www.parallax.com/dl/docs/cols/nv/vol4/col/94.pdf
http://www.parallax.com/dl/docs/cols/nv/vol4/col/95.pdf
-- Jon Williams
-- Dallas Office
From: John Remington [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z-SIctxQGEptAk6ViiquPEMZlwk4UnAXZdVVsXbCCcx9r_qCU1nGWMQO8V61VlAbHtajD6JJiL3s]jrem123@y...[/url
Sent: Sunday, November 02, 2003 5:34 PM
Subject: Re: [noparse][[/noparse]basicstamps] small MIDI question
that's a send, the receive are optically isolated. A typical stamp
> view
> ryan
Do you Yahoo!?
abuse@p....
My midi project didn't work immediatly. I had to put a buffer (or 2
inverters) between the output pin and the resistor. Now it works fine.
Maybe the MIDI device I want to control needed more power than usual to get
it working...
I hope this helps
>ryan
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>Incoming mail is certified Virus Free.
>Checked by AVG anti-virus system (http://www.grisoft.com).
>Version: 6.0.530 / Virus Database: 325 - Release Date: 22/10/2003
Outgoing mail is certified Virus Free.
elsewhere...). If you have the jack, though, it will have the pins
numbered, and the document you reference was fairly explicit as to which
pin numbered was +5/gnd/data.
> ryan
Sean T. Lamont, Chief Mad Scientist |-- lamont@a...
Zen Chemical Productions |-- http://www.zenchemical.com
Fabricators of Unnecessary Amazement
remember the baud rate limit on the BS2, but MIDI at 31.25 baud is quite
within its practical range. (I actually used 32768 baud which seems for
some reason to work better...)
BTW, optoisolation is in the MIDI spec because you don't want stray
voltage from speaker coils, etc. flowing through midi cables & blowing up
your processor, then continuing down the bus to the next device. In
practical means, you don't have to optoisolate it and it works fine. Just
be prepared to replace the BS2 if you have such a spike.
> > view
> > ryan
> Do you Yahoo!?
