Serial Communication Application
I need help on the following application.
I need to monitor a serial stream where the start of the stream is @@
+ 121 bytes of data and the end 4 bytes.
What I need to do is monitor the 100th byte of data. bases on the
100th byte I need to do something. Can you please post an example of
the code that I would need when using a stamp II
Thank you
Mauro
Thank you
Mauro
You could try something like this:
InterestingByte var byte
SERIN 0,16468,[noparse][[/noparse]WAIT("@@"), SKIP 99, InterestingByte]
The SERIN command above will wait for the start of your serial data stream
and after a further 99 bytes will store the value of the next (hundredth)
data byte in the variable InterestingByte.
Best regards,
Russell Warburton
email: russell@w...
website: http://www.warburtech.com
telephone: +44 (0)7814 044 754
Sent: Saturday, November 01, 2003 8:03 PM
Subject: [noparse][[/noparse]basicstamps] Serial Communication Application
> Thank you
> Mauro
II for this purpose. It is no problem at 2400 baud, but it would be
at full out 9600 or more.
-- Tracy
>Hi Mauro,
>Best regards,
>Russell Warburton
>email: russell@w...
>From: "mdbware2000" <mdbware@h...>
>> Thank you
>> Mauro
>Subject and Body of the message will be ignored.
The baud rate will be 9600.
I am ok in using a stamp II
Thank you
Mauro
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> What is the baud rate? That makes a difference for using the
Stamp
be
> -- Tracy
> >Hi Mauro,
data stream
(hundredth)
> >Best regards,
> >Russell Warburton
> >email: russell@w...
is @@
the
example of
> >> Thank you
> >> Mauro
Subject and
Thank you
Mauro
Stamp
be
> -- Tracy
> >Hi Mauro,
data stream
(hundredth)
> >Best regards,
> >Russell Warburton
> >email: russell@w...
is @@
the
example of
> >> Thank you
> >> Mauro
Subject and
your BS2 at 9600 baud, don't be too surprised. The code is good,
it's just that the BS2 might have trouble keeping up. If you have
any control over the transmission at the other end, the situation can
be improved by setting it for 2 stop bits, or for 1 millisecond or
more of pacing, or for a lower baud rate.
If not, you might get better results with a Stamp 2sx or 2p, or, by
using an external RS232 chip with a large enough buffer.
-- Tracy
>Thank you for the reply.
>Thank you
>Mauro
>Stamp
>be
>> -- Tracy
>> >Hi Mauro,
>data stream
>(hundredth)
>> >Best regards,
>> >Russell Warburton
>> >email: russell@w...
>is @@
>the
>example of
>> >> Thank you
>> >> Mauro
>Subject and
