StampPlot Pro Version 3 Release 2 is available
StampPlot Pro Version 3 Release 2.1 is available for download.
http://www.stampplot.com
Remember, StampPlot Pro - Standard license allow FREE use by home and
educational institution users!
Updates:
Plotting from a standard log file
It is now possible to plot data collected from in data log files, either as
raw data, or historical with proper date/times and intervals.
Saving settings
Some plot parameters (Axis values and labels, real time setting, log scales
setting) and all current values of plot control objects can be stored to the
Windows registry and recalled. Updated installed macros to allow
saving/loading of settings.
File and toolbars opens various file types
The 'Open Plot' and the Open button on the toolbar allows opening of plot
file (*.plt), macros (*.spm), snapshots (*.jpg) and data files (*.txt) using
the respective programs for each.
Limiting file sizes.
The data and message files may be size limited by the number of KBytes to
save, the remainder is truncated.
OAnalog Object Routine
An oAnalog selection has been added to allow event code to be ran on the
arrival of analog data. This allows manipulation of analog data without
having to use the DEFAULT macro routine or DA_ Object names.
The hot-Key for running the start-up macro has been changed to CTRL-F1.
The license names have been modified to the following:
StampPlot Pro - Developer's License for the ability use the macro editor and
object builder.
StampPlot Pro - Standard License without the editor options.
Sincerely,
Martin Hebel & Will Devenport
SelmaWare Solutions
Updates:
Saving settings
object builder.
Sincerely,
SelmaWare Solutions
