new to quadravox — Parallax Forums
new to quadravox
edited 2003-10-29 20:09 in General Discussion
I am tring to work with quadravox. To help learn it I want to have to
switchs when swith one is presses sound one is played when switch 2
is pressed sound two plays.
Here is some of my sample program can someone please look at it and
tell me if and where I am going wrong.
' I/O def
QV_RST CON 0 ' QV306M4.14
QV_RX CON 1 ' QV306M4.1
QV_TX CON 2 ' QV306M4.2
QV_BUSY VAR In3 ' QV306M4.3
[noparse][[/noparse] Constants ]
T2400 CON 396 ' 2400 baud, true
IsBusy CON 0
' ** QV306M4 Command Set **
QV_Direct CON $F0 ' QV modes
QV_Stop CON $F6
QV_Sleep CON $F8
QV_Volume CON $FC
QV_Reset CON $FD ' software reset
QV_Rev CON $FE ' module revision
QV_Type CON $FF ' module type
[noparse][[/noparse] Vocabulary ]
_s1 CON 0
_s2 CON 1
[noparse][[/noparse] EEPROM Data
Sound1 DATA _s1
Sound2 DATA _s2
I understand how to use the switchs to choose but I do not understand
how to call the sound up.
Please Help
Brian
    You seem to be defining your switches on pins used by the BASIC Stamp to
    talk with the QV306 -- this is a possible problem. Update the program
    to PBASIC 2.5 syntax with the PIN definition to make things easier, and
    put your buttons on pins 14 and 15 (since they are not used).
    S1 PIN 14
    S2 PIN 15
    Then later...
    Main:
    IF (S1 = 1) THEN
    phrase = _S1
    GOSUB Say_Phrase
    ENDIF
    IF (S2 = 1) THEN
    pharse = _S2
    GOSUB Say_Phrase
    ENDIF
    GOTO Main
    I will update the QV306 demo code and have it posted on our web site.
    -- Jon Williams
    -- Dallas Office
    From: bknob2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=j1NsZA8_qP8vUC-VpHGKDKMyA7bz0lnor3Po82bGrfCMFu10InzP8tli0FWIRqttRWWV]bknob@a...[/url
    Sent: Wednesday, October 29, 2003 2:01 PM
    Subject: [noparse][[/noparse]basicstamps] new to quadravox
    ' I/O def
    IsBusy CON 0
    QV_Stop CON $F6
    QV_Sleep CON $F8
    QV_Volume CON $FC
    _s1 CON 0
    _s2 CON 1
    Sound1 DATA _s1
    Sound2 DATA _s2
    Please Help
    Brian
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
