H-Bridge Debugging
Good Morning-
Long time listener first time caller... I'm trying to debug a H-Bridge
circuit I just built (standard h-bridge,
http://www.solarbotics.net/library/circuits/driver_tilden.html)
Basically it doesnt work. To test it I wrote a program:
start:
LOW 1
HIGH 0
PAUSE 1000
LOW 0
HIGH 1
PAUSE 1000
goto start
to switch between power on one side and the other. This should manifest
itself in the motor switching directions. Rather, it just chugs forward.
Also, my 3.6v AA battery pack wont power the motor (which it does straight
up connecting it).
The only difference I have between the listed circuit and my own is no
resistors... but this shouldnt change the properties of the circuit.
Using a voltmeter, I verified the output of pin 0 and 1. I also checked
the inputs to the bridge, they were nominal. Testing the motor outputs of
the bridge revealed a constant voltage, consistent with the motors going
full boreforward, but it should be flip-flopping every second.
Any ideas?
Phil
start:
LOW 1
HIGH 0
PAUSE 1000
LOW 0
HIGH 1
PAUSE 1000
goto start
up connecting it).
Any ideas?
Phil
http://www.geocities.com/jimforkin2003/
jim
From: Philip Hahn [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nWaGBqdbW2icMA2pywXvGwX05mx0cuHqBaeVny6rBl2p3CQWoxfFlXYuAZYgAh1QJMjwmdwHHw]phil@n...[/url
Sent: Wednesday, October 29, 2003 4:42 AM
Subject: [noparse][[/noparse]basicstamps] H-Bridge Debugging
Good Morning-
start:
LOW 1
HIGH 0
PAUSE 1000
LOW 0
HIGH 1
PAUSE 1000
goto start
up connecting it).
Any ideas?
Phil
> Good Morning-
Bridge
> start:
> LOW 1
> HIGH 0
> PAUSE 1000
> LOW 0
> HIGH 1
> PAUSE 1000
> goto start
manifest
forward.
straight
> up connecting it).
no
checked
outputs of
going
> Any ideas?
> Thanks
> Phil
Add pull down resistors on the signal lines.
Also transistors will need enough current on the base to allow power
thru them. since you want them staruated, check the Hfe and make
sure you are providing enough power.
This can be tested by monitoring the voltage on the base of the PNP
and NPN units that are activated and verifying zero on the base of
the ones not.
possibly add pull down resistors on the base of the PNP and NPN as
well.
Dave
I wasn't sure what the current your motor uses and which transistors
you are using.
the 3904/6 are typically 100mA, with some at 200ma. If your motor is
still slow, the motor may not be getting enough current.
Dave
--- In basicstamps@yahoogroups.com, "Philip Hahn" <phil@n...> wrote:
> Good Morning-
Bridge
> start:
> LOW 1
> HIGH 0
> PAUSE 1000
> LOW 0
> HIGH 1
> PAUSE 1000
> goto start
manifest
forward.
straight
> up connecting it).
no
checked
outputs of
going
> Any ideas?
> Thanks
> Phil
