Small pulsed voltage
Hey guys,
I've got to resolve a wind speed from some equipment.
I get 3 pulses per revolution from a 'tristate' magnet....(not sure about
this..but it's what the guy said! [noparse]:p[/noparse] )
As it speeds up, the pulses increase in frequency (uh..duh!)...but the
voltage level goes up slightly.
I DON'T believe the voltage gets to any great level....SO....
If stuck with a signal level around 200mV-500mV....I don't want to use too
many components or lose any pulses/resolution....
OpAmp the easiest way?
I thought of a Freq-to-Voltage converter chip that I got...but STILL...low
levels eh!
Uh....I'm thinking and typing here....3906npn....
Pulsed goes through the base with the collector to Vdd and emitter to Vss
(Vdd=+5; Vss=Gnd).
Toss a couple resistors and maybe a cap...:S
Have to keep the component count down....
Ah Well
sb
levels eh!
(Vdd=+5; Vss=Gnd).
Ah Well
sb
I'm sending it again!
Hey guys,
this..but it's what the guy said! [noparse]:p[/noparse] ) As it speeds up, the pulses increase
in frequency (uh..duh!)...but the voltage level goes up slightly. I DON'T
believe the voltage gets to any great level....SO.... If stuck with a signal
level around 200mV-500mV....I don't want to use too many components or lose
levels eh! Uh....I'm thinking and typing here....3906npn....
(Vdd=+5; Vss=Gnd). Toss a couple resistors and maybe a cap...:S Have to keep
Ah Well
sb
I don't think the 3904 will work. You will need about 0.6 volts minimum to
overcome the Base Emitter Junction.
I think an op-amp comparitor (LM311) will work well. Set up a simple voltage
divider so the minus lead is at 0.3 volts.
The only problem I see with this solution is "part/pin" count. Of course the
3904 is 3 leads and a few resistors.
The LM311 is an 8p pin dip, and a few resistors.
Ken
Hey guys,
levels eh!
(Vdd=+5; Vss=Gnd).
Ah Well
as it turns induces a voltage in a coil on the stator. (Classic
tachometer). Both the frequency and the voltage increase as the cups
go around faster, as you noted. The voltage is AC, from 10
millivolts up to several hundred millivolts.
The LM2917 is a tachometer interface circuit. It can be configured
as a frequency to voltage converter, or, for COUNTing, it can put out
conditioned 5 volt pulses (8-pin dip + a couple of Rs).
-- Tracy
>Sorry if this is a double post...I didn't see in come out in the group so
>Hey guys,
>Ah Well
>sb
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
