windows 2000 won''t identify my Basic Stamp2 chip
Ok, maybe some more info would have been usefull.
system: windows 2000, 1GhzPIII, plenty of RAM,
The stepper motor controller has been running for about 5 years without a
problem on a windowsNT4 machine which died when it was patched to
service pack6, other machines i have can identify the chip on the stepper
motor controller yet when i put it in this new machine it can't identify it. If
i
take a basic stamp on a bread board it can identify that chip using the same
RS232 cable ...... i have no idea whats going on.
Matt.
On 28 Oct 03, at 15:51, Sam wrote:
> =has it recognized the stamp in the past?
> =when did it stop recognizing it? (did it stop working after testing
> out the servo motors for the first time with the stamp?)
> =check power to the stamp, if using a battery, us a new one, or
> consider using an AC wall adapter (AC in, <10V DC out).
> =how are you powering the servo motors? Same power supply as stamp?
> =if you were able to program the stamp in the past, does the last
> program that you downloaded to it still work. (can you tell if the
> stamp is broken or not in any way).
> =have you tried restarting the computer
> =give any other info that you think might be helpful in diagnosis of
> a problem.
> --- In basicstamps@yahoogroups.com, "Matt Harper" <phymjh@p...>
> wrote:
> > I was wondering if anyone could help with a problem i have.
> > I am running windows 2000 and using a basic stamp2 chip to control
> > some stepper motors.
> > the problem i am having is that when i try and identify the chip
> > using the stamp editor software it does not detect/identify the
> chip.
> > i have made sure all of the comm port settings are correct does
> > anyone have any ideas on what i can try to solve the problem?
> > Thanks
> > Matt.
of the message wil
l be ignored.
i
Matt.
> a problem.
> chip.
> > Thanks
> > Matt.
of the message wil
l be ignored.
