Joystick interface basics
I'd like to hook a Joystick up to a BS2 to control 2 servos for a
tilt/pan application. Has anyone done this before? I searched
online and on LOSA for source code and all I found were dead links.
Thanks!
Thanks!
article from Nuts & Volts:
http://www.parallax.com/dl/docs/cols/nv/vol2/col/70.pdf
-- Jon Williams
-- Dallas Office
From: Chris Drzewiecki [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EiJy-Z4WLrfT1MIfmKnTdlPKLf2ftikbdnMh_AdBpkkXvJnntwseviZ9NTqTDbkcuRaUUwpT-ZhLr10]crd75@a...[/url
Sent: Tuesday, October 28, 2003 12:24 PM
Subject: [noparse][[/noparse]basicstamps] Joystick interface basics
Thanks!
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
be able to control 2 independent servos?
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> It's pretty easy to do with an old analog joystick. Take a look
at this
> -- Jon Williams
> -- Dallas Office
> From: Chris Drzewiecki [noparse][[/noparse]mailto:crd75@a...]
links.
> Thanks!
Subject
> abuse@p...
of RCTIME, you could use a two-channel ADC like the LTC1298. You can
use PULSOUT to update your servos...like this:
Update_Servos:
PULSOUT Servo1, s1width
PULSOUT Servo2, s2width
PAUSE 10
RETURN
At its worst case, this subroutine should take about 15 ms to run --
this gives you 5 ms to read the joystick and calculate the servo values.
Now, truthfully, if you just want to make a couple of servos follow a
joystick, you can do it with a couple of 556 timer chips and discrete
parts. If you want to do it in a micro and do it "on the cheap" you
could certainly use the BS1 which is making a come-back with a new
Windows editor to be released shortly.
-- Jon Williams
-- Dallas Office
From: Chris Drzewiecki [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HeVsee_L9Y0cLAcwdhsWxg7sxmZvj6iGuhK1M__IwocOKIHR2z_UsL8s4vyFuMBvAbiuT8TxMMpO3ngT2Q]crd75@a...[/url
Sent: Tuesday, October 28, 2003 2:03 PM
Subject: [noparse][[/noparse]basicstamps] Re: Joystick interface basics
Thanks. How accurate is the positioning with it? Also would a BS2
at this
> -- Jon Williams
> -- Dallas Office
links.
> Thanks!
Subject
> abuse@p...
abuse@p....
getting much more it would be great. Basically, I do want the 2
servos to follow the joystick. And eventually making it a wireless
connection. I want to use one of the buttons on the joystick to
trigger a switch that's hooked up to an electronic trigger on a
paintball gun. Basically it's going to be a remote controlled
turret that will eventually be phased into a robot rover. Sounds
crazy, huh [noparse]:)[/noparse]
wrote:
> The accuracy will depend on the joystick pots and the A/D used.
Instead
can
> Update_Servos:
> PAUSE 10
> RETURN
values.
follow a
discrete
you
> -- Jon Williams
> -- Dallas Office
BS2
<jwilliams@p...>
> at this
> > -- Jon Williams
> > -- Dallas Office
> links.
> > Thanks!
> Subject
to
> > abuse@p...
Subject
> abuse@p...
