: [basicstamps] sound
you can hardwire the Record module found at radioshack. it is very small
and can store up to 20 sec of anything. you would just Have to trigger the
play cycle on the module.
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5\
F011%5F005%5F000%5F000&product%5Fid=276%2D1323
At 10:20 PM 10/28/2003 +0100, you wrote:
>What is that
>natacha
Message d'origine
>De : Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TtOlVIxy3P6Nu1z2gtpF9o4OYSFXi7cRSpiZ-QyE0fZVe24IXA4Gv9UD2GXYFqG1WvvqCRDK1CTgbTfJdO8]crazykurby@y...[/url
>Envoy
>What is that
>natacha
Message d'origine
>Envoy
In fact I want to play back a really small rythmic file size: 1.61 ko
size on disk 16 ko
My concern is how to save it on the stamp
Natacha
Message d'origine
De·: Robert Ussery [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZFynmVg17RGpWb8EfFD6opnuC6RFER3_35IR5cs3jtJ9_8BVPpXXwP8s0VYXNZG7Kb9NIVcnwhZ0]uavscience@f...[/url
Envoyé·: 27 octobre 2003 22:45
À·: basicstamps@yahoogroups.com
Objet·: Re: [noparse][[/noparse]basicstamps] sound
Sure, depending on just how large/complex the sound file is.
For instance, you could play back a simple sequence of tones several
minutes
long, but it might be impossible to play back more than a fraction of a
second of voice-type sound. Just what do you have in mind?
- Robert
> Thanks to anyone who culd help me with this
> is it possible to recrd and play back a very small sound file on to a
basic stamp?????
Your use of Yahoo! Groups is subject to
other chip since my project is getting sound out of clothing wich means
as little electronic as possible I guess I am going to pursue with
frequout even if it is limited
natacha
Message d'origine
De·: Gary W. Sims [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T0mH2JQFBbUXK07Ek_0rnOJo2W1zBTtKVeXg9Nucu41c_PgRB5DW1Y2cOc3MWUonaCRHGHoLkcstVIsrUvk]simsgw@c...[/url
Envoyé·: 28 octobre 2003 04:05
> [noparse][[/noparse]...] I want to play back a really small rythmic file
> size: 1.61 ko size on disk 16 ko
Would that be 1.61 kilobytes, Natacha? That's a very big file for a
Stamp.
The memory available is different on different models, but BS2 for
example
has only 2 kilobytes total and that has to handle the program as well.
More important, I suspect that 1.6 kb is a file in some standard format,
like a WAV file. It's not impossible, but I've never heard of code to
play
back a WAV file -- or any standard audio file format on a Stamp. What
you
would need to do is add one of the special chips programmed for that
purpose. Then you load the audio file on that chip with the memory it
provides.
Parallax offers several audio add-on units for the Stamp. Check:
http://makeashorterlink.com/?W11125B56
Without that, I think you'll be limited to writing your own little tune
using the simple tones a Stamp can generate with the FREQOUT command. If
you
have musical ability that can be pretty impressive. It's just a lot of
work
to prepare the notes.
Gary
natacha
Message d'origine
De·: Kyle Cooper [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=y-8_P_Wk0WH53zPnyPccPSyPeaFbOBEWHJ2LjKm0olVlKOaGj3OuB8Nvuj2OOXI8QM1yhtILLGlh6jxrinU]crazykurby@y...[/url
Envoyé·: 28 octobre 2003 03:07
yeah, you can play wav. files with Quadravox QV430P Sound Programmer [noparse]:)[/noparse]
basic stamp?????
Post your free ad now! Yahoo! Canada Personals
Do you Yahoo!?
Exclusive Video Premiere - Britney Spears
