windows 2000 won''t identify my Basic Stamp2 chip
=has it recognized the stamp in the past?
=when did it stop recognizing it? (did it stop working after testing
out the servo motors for the first time with the stamp?)
=check power to the stamp, if using a battery, us a new one, or
consider using an AC wall adapter (AC in, <10V DC out).
=how are you powering the servo motors? Same power supply as stamp?
=if you were able to program the stamp in the past, does the last
program that you downloaded to it still work. (can you tell if the
stamp is broken or not in any way).
=have you tried restarting the computer
=give any other info that you think might be helpful in diagnosis of
a problem.
--- In basicstamps@yahoogroups.com, "Matt Harper" <phymjh@p...>
wrote:
> I was wondering if anyone could help with a problem i have.
> I am running windows 2000 and using a basic stamp2 chip to control
> some stepper motors.
> the problem i am having is that when i try and identify the chip
> using the stamp editor software it does not detect/identify the
chip.
> i have made sure all of the comm port settings are correct does
> anyone have any ideas on what i can try to solve the problem?
> Thanks
> Matt.
a problem.
chip.
> Thanks
> Matt.
