help to shorten code
I was wondering if you could help me shorten the code and tell me how how to
make it loop a certain amount of times. I have tried several ways too but all of
them didnt work.
The code is to control rudders on a model airplane.
here is the code.
resetb2: b2=100
servo: pulsout 6,b2
pause 20
let b2=b2+2
if b2>600 then resetb3
pause 5000
resetb3: b3=600
pulsout 6,b3
let b3=b3-2
if b3<100 then resetb2
Do you Yahoo!?
Exclusive Video Premiere - Britney Spears
them didnt work.
here is the code.
resetb2: b2=100
servo: pulsout 6,b2
pause 20
let b2=b2+2
pause 5000
resetb3: b3=600
pulsout 6,b3
let b3=b3-2
Do you Yahoo!?
> me how how to make it loop a certain amount of times. I have
> tried several ways too but all of them didnt work. The code is
Actually, Kyle, I can't understand exactly what sequence of actions you're
trying to create. Maybe you can explain a little more. Here's what I get
from the code right now:
> resetb2: b2=100
> servo: pulsout 6,b2
> pause 20
> let b2=b2+2
> pause 5000
This loop will never jump to resetB3, because it can't reach 600. B2 is a
byte, so its highest value is 255. It appears you want to wait five seconds
after pulsing pin six and then... then pulse pin six again.
Are you trying to put out increasingly higher pulse positions until they
reach 600, and then decrease them back to 100? If so, you must be careful.
Not many servos will accept a pulse width in that range. If your Stamp is a
BS1 that is 1 millisecond to 6 milliseconds. If you have a BS2, the range
will be 0.2 milliseconds to 1.2 milliseconds. A typical hobby servo will
accept pulses between one and two milliseconds. Check your arithmetic and
make sure you know how long a pulse you're trying to emit.
I said that last snippet of code would not jump to "resetB3" because the
test for B2>600 can never succeed, but it will "fall through" after that
five second pause. Then we have:
> resetb3: b3=600
> pulsout 6,b3
> let b3=b3-2
and again B3 cannot equal 600. Offhand, I think the assignment B3=600 will
result in B3 holding the value 88. That means the test b3<100 will succeed
and you're back to the top of the routine.
May I suggest a coding technique? Use FOR loops to repeat your pulses. One
to step up from the shortest pulse and another to step back down from the
longest pulse. Don't use GOTO statements unless you absolutely must. It is
very difficult to keep track of our own code if we let it jump around from
here to there.
Moving from a short pulse to a long one and back again would look like this
using FOR loops.
'First some names so we can keep track of what our numbers mean
MinPulse CON 100
MaxPulse CON 200
RudderServoPin CON 6
Waggles CON 3
PulseDuration VAR Byte
WaggleCount VAR Byte
'Then an outer loop to control how many times we waggle the rudder
FOR WaggleCount=1 TO Waggles STEP 2
'First, we move the rudder servo to a longer pulse width
FOR PulseDuration=MinPulse TO MaxPulse
PULSOUT RudderServoPin, PulseDuration
PAUSE 20
NEXT
'Now we move the rudder servo back to shorter pulse widths
FOR PulseDuration=MaxPulse TO MinPulse STEP 2
PAUSE 20
NEXT
'That completes one waggle. Now repeat as required.
NEXT
Incidentally, as a pilot the notion of increasing my rudder deflection more
and more over a period of twenty minutes worries me. That's what your
original code would do with that five second pause between each step. I
would expect to auger into the ground after the first minute or so.
If you want to waggle the tail, I'd remove that five second pause. With the
minimum 20 millisecond pause between each pulse to the servo, that FOR loop
above will spend about one second moving the rudder one way and then one
second back the other. I figured that by multiplying the fifty steps times
20 milliseconds. That's 1,000 milliseconds, or one second. That won't give
your airplane enough time to roll inverted and dive into the ground while
it's at full rudder in either direction.
Notice that I used a range from 100 to 200. That's about right for a BS1 and
a standard servo, but "about right" is not good enough. You'll burn out a
servo that way. You need to find out how long a pulse will work with your
servo. Start in the middle and work to changes that are greater and greater
until you can see the servo is reaching it's limit. You might write
something like:
Center CON 150
Delta CON 10
Cnt VAR Byte
FOR Cnt=1 to 20
PULSOUT RudderServoPin,Center
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PULSOUT RudderServoPin,Center-Delta
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PULSOUT RudderServoPin,Center+Delta
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PAUSE 20
NEXT
END
This will center the servo, move it one way, and then the other. That's how
I test a new servo. You have to guess about the first value for "Center". On
a BS2 I use 750 which gives a pulse length of 1.5 milliseconds. On a BS1,
150 gives that same pulse length.
Run this program. Watch where the servo moves. Change the value of Center
until the rudder is at the center position after the last movement ends.
Now change the value of Delta. Try perhaps 20 or 25, and run the program
again. Keep increasing Delta until the servo is near it's limits. If the
servo reaches its limit one way or the other before the rudder is at the
position you want to reach, you will have to adjust the control horn on the
servo. That's too long a procedure to go into unless you need to know.
Hope all this helps. Read the Stamp manual on FOR loops. They help a lot.
Gary
"Gary W. Sims" <simsgw@c...> wrote:From: "Kyle Cooper"
> resetb2: b2=100
> servo: pulsout 6,b2
> pause 20
> let b2=b2+2
> pause 5000
> resetb3: b3=600
> pulsout 6,b3
> let b3=b3-2
here to there.
using FOR loops.
MinPulse CON 100
MaxPulse CON 200
Waggles CON 3
PAUSE 20
NEXT
PAUSE 20
NEXT
NEXT
something like:
Center CON 150
Delta CON 10
Cnt VAR Byte
FOR Cnt=1 to 20
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PAUSE 20
NEXT
END
Gary
from the same email address that you subscribed. Text in the Subject and Body of
the message will be ignored.
Do you Yahoo!?
> Thank you very much Gary this is my first project with servos
You're welcome, Kyle. Let us know if you need more help.
Gary
looked through the book but probably missed it.
Gary
Do you Yahoo!?
> What does the CON stand for? after I typed the
> program it put CON as an error.
No that was my mistake, Kyle. You clearly are using the BS1, and I did not
realize the editor for the BS1 defines constants in a different way. (I have
it on hand, but haven't used it yet.) CON and VAR are different ways to
define symbols in the later version of the editor. For your editor, make
that code read like this:
symbol MinPulse=100
symbol MaxPulse=200
symbol RudderServoPin=6
symbol Waggles=3
symbol PulseDuration=B0
symbol WaggleCount=B1
The rest should compile correctly, though I can't be sure without shutting
down my system and starting up the first-version editor from a floppy. I'll
try it later tonight and let you know if I made any other mistakes.
Gary
Gary
symbol MinPulse=100
symbol MaxPulse=200
symbol Waggles=3
Gary
Do you Yahoo!?
couldn't get the code to repeat it. The motor only goes through the program once
and stops could somebody help or tell me what I'm doing wrong. : )
> resetb2: b2=100
> servo: pulsout 6,b2
> pause 20
> let b2=b2+2
> pause 5000
> resetb3: b3=600
> pulsout 6,b3
> let b3=b3-2
here to there.
using FOR loops.
MinPulse CON 100
MaxPulse CON 200
Waggles CON 3
PAUSE 20
NEXT
PAUSE 20
NEXT
NEXT
something like:
Center CON 150
Delta CON 10
Cnt VAR Byte
FOR Cnt=1 to 20
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PAUSE 20
NEXT
PAUSE 1000
FOR Cnt=1 to 20
PAUSE 20
NEXT
END
Gary
Do you Yahoo!?
> Sorry for asking about this problem now (been busy last few
> weeks), but [noparse][[/noparse]...]
Yes, here too, Kyle. Can't remember where we left off exactly...
> I couldn't get the code to repeat it. The motor
> only goes through the program once and stops could
I'm guessing, but I think you're probably talking about the code I posted
that begins:
> Center CON 150
> Delta CON 10
> Cnt VAR Byte
> FOR Cnt=1 to 20
> PAUSE 20
> NEXT
> [noparse][[/noparse]...and so forth]
That is a calibration program. The code is only intended to run once each
time you download it. Watch the action of the servo, then edit the constants
and download it again. If I remember correctly, your Stamp is a BS1 so the
code had to define the constants differently, but I'm too tired tonight to
remember how it is done in PBasic 1.0. (We were busy with some medical
problems here, and I'm a little fuzzy<g>.)
Start with "Center". You need to find out what the correct value is for the
servo pulse to put the rudder exactly in the center. Run the code as above
and see if the rudder is exactly centered. It won't be this first time.
Let's suppose it was to the left of center. Now change the "Center" value in
that constant statement to be 160. Download the changed program and watch
the rudder. Did it move toward the center? Or away? If it moved toward
center, then you know higher numbers move the rudder right. Now keep
increasing the value and running the program again until the rudder is
centered.
If it was further away when you changed the value to 160, then you know that
higher numbers move the rudder to the left. Write down this information in
either case. You will need when you write other programs. You want to know
whether small numbers put the rudder to the left or the right. Now start
using smaller numbers, and running the program after each change, until you
find the center.
Once you find the center value, write that down also. Now start increasing
the value "Delta" (a word which means the difference between two values).
We're going the find the difference between the center position and the two
extremes, left and right. Gradually increase "Delta" in that statement and
download the changed program each time. Watch the rudder to make sure you
notice when it reaches the limit of movement. Write down that value of
Delta.
Let's suppose you found out the smaller values move the rudder left of
center. Now whenever you want to move the rudder full left, you would say:
PULSOUT RudderServoPin, Center-Delta
Or you could just add a statement defining two new constants:
RudderLeft CON Center-Delta
RudderRight CON Center+Delta
For a BS-1 you might have to subtract and add for yourself and put the
actual result in the statement. Check your language manual or someone else
here can tell you. Once you have those constants, you can write code like
this:
PULSOUT RudderServoPin, RudderRight
Then you put statements like that inside a FOR loop and you can waggle the
rudder back and forth as many times as you want.
Hope this helps. Good luck,
Gary
you went over that program too. thanks Gary sorry I wasn't specific. I went
through the program several times and the motor would only go through one waggle
but everything looks ok.
on 1 line of code changed 2 to -2
for pulseduration=maxpulse to minpulse step -2
that begins:
> Center CON 150
> Delta CON 10
> Cnt VAR Byte
> FOR Cnt=1 to 20
> PAUSE 20
> NEXT
problems here, and I'm a little fuzzy.)
centered.
find the center.
Delta.
this:
Gary
Do you Yahoo!?
> [noparse][[/noparse]...] everything looks ok. on 1 line of code changed 2 to -2
I speak subject to correction, but unless the PBasic 1.0 is different from
my PBasic 2.5, I believe you must specify the step with a positive value.
The interpreter sees that the end value is lower than the start value and
decrements automatically. If you specify a negative step, you confuse
things, and that might well cause the loop to execute only once.
I haven't used loops that step downward lately, but I'm pretty sure that's
how it works.
Gary
I changed it the motor went back and forth once. I cant figure out why it is not
repeating.
I know I gotta be doing something wrong but thanks for your help Gary.
how it works.
Gary
Do you Yahoo!?
