Q: GPS Data logger
Archiver
I have yet to hear back from anyone on experience with writing GPS Data
Logger code. Has anyone done it?
Dave
dtcasey@c...
From: Dave Casey [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZQYv2WUgx-6yxf8GmIoX3ZG2Y_IKhSKptkDK6q_wRIcicOhhrayP-gdCi9VkSqb2IW3ZURQTKNV7PRc]dtcasey@c...[/url
Sent: Friday, October 24, 2003 9:56 AM
Subject: [noparse][[/noparse]basicstamps] More GPS Questions
I would like to build a GPS data logger similar to the one referenced in
the Where in the World is My Basic Stamp paper. Jon Williams refers to
a project where GPS data was logged from a radio controlled plane, but
all I can find is a video of this project and not the code. Does anyone
have code or info on how to do this? Does anyone have an estimate of
how many lines of NMEA Lat/Long & time data a BS2 can store?
Dave
David Casey
dtcasey@c...
From: Wally [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OHOrbr2-FMSN1xGFoQjQ0lItYupGNahmMA72yZYHpI9JQh2C9qNgbV5EpcZbRk-cbCLm5jdJaQ4N7VXv]dogiewal@n...[/url
Sent: Sunday, October 19, 2003 4:26 PM
Subject: [noparse][[/noparse]basicstamps] Re: lat/long calculations GPS
Outstanding! And thank you, thank you.
Now, has anyone worked with the output of Delorme's "Tripmate"?
-- Wally
--- In basicstamps@yahoogroups.com, "Atomic Nixon" <atomicnixon@h...>
wrote:
> --- In basicstamps@yahoogroups.com, "Wally" <dogiewal@n...> wrote:
> > Can't seem to locate N & V column #83. Can you tell me the issue
> date
> > in which it appeard - please.
> > -- Wally
> > --- In basicstamps@yahoogroups.com, kgregory@g... wrote:
> > > Where in the World is My BASIC Stamp? Nuts n Volts Stamp Column
> #83
> It's there.
> http://www.parallax.com/dl/docs/cols/nv/vol3/col/83.pdf
> 'tomix
Your use of Yahoo! Groups is subject to
Dave
dtcasey@c...
Dave
David Casey
dtcasey@c...
-- Wally
> date
> > -- Wally
> #83
> It's there.
> 'tomix
a BS2p uP.
This uP has 8 banks of 2K eeprom, but 1 bank must hold the program.
To use the uP, to store all logging, is not the best solution. Still
it's room for 14 000 letters/numbers, and since one GPS position
will use 20 letters, you could store 700 readings. If you want time
and date as well, then you must store 15 extra numbers. Then you're
down to 400 readings.
The M95256-WBN6 is a SPI Eeprom DIL8 with 32K. That's 32000 numbers
or 1600 positions (in theory). Cost 3-4US$. Look at the "8K serial
Eeprom application" from parallax. The program is simple to
understand. Remember that Eeprom and the uP can only be erased 100
000 times.
Stein.
Stein_Frostad at mailcity dot com
--- In basicstamps@yahoogroups.com, "Dave Casey" <dtcasey@c...>
Data
> Thanks,
> Dave
> dtcasey@c...
> From: Dave Casey [noparse][[/noparse]mailto:dtcasey@c...]
referenced in
refers to
but
anyone
of
> Thanks,
> Dave
> David Casey
> dtcasey@c...
> From: Wally [noparse][[/noparse]mailto:dogiewal@n...]
> -- Wally
<atomicnixon@h...>
issue
> > date
> > > -- Wally
Column
> > #83
> > It's there.
> > 'tomix
Subject
Subject
