Connecting BS2 to BS1
I have a BS2 that I am trying to connect to a BS1. On the BS2 I have
the following test code in a loop
serin 8, 396, [noparse][[/noparse]MyByte]
Debug DEC MyByte, CR
on the BS1 I have the following in a loop
serout 3, T2400 (B0)
Pause 100
let B0 = B0 + 1
The trouble is that on the BS2 I receive data but it's all garbled. I
tried to reduce the baud rate to 1200 but no luck.
I have connected the two devices by putting a 10K resistor between
BS2 Pin8 and BS1 Pin 3.
Is this the right approach?
P.S.
I'd rather not use the open drain method mentioned in the Parallax
manual. I eventually want to substitute a PIC for the BS1 and it
doesn't support open drain in it's serin/serout parameters.
The code above is from memory too, so please ignore any obvious
typos. :-)
Pause 100
let B0 = B0 + 1
P.S.
typos. :-)
the two; I have a BS1 "slave" running a simple process for a BS2
"master" on my desk right now (for the December Nuts & Volts). Now, I
am using and open drain connection in the project, but I removed my
pull-up and switched to a driven mode with no problems.
Here's how I define baud rate parameters on the BS2 side:
#SELECT $STAMP ' baud rate parameters
#CASE BS2, BS2E, BS2PE
T1200 CON 813
T2400 CON 396
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
#ENDSELECT
Inverted CON $4000
Open CON $8000
Baud CON T2400
...and on the BS1 I am using a baud rate parameter of T2400.
Note that my project has data going both directions (the BS2 can send
commands to and request data from the BS1) so (like you) I changed the
link to a 1K to make sure that a programming error on my part doesn't
lead to a busted pin.
-- Jon Williams
-- Dallas Office
From: myfakeuser [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=W-5MOwODlgVhsYGd-2rrZcqgtqZLUbQ2WmKU334kb-zEKZ1Vy7vqvoy4VcI4YL2h9cwJ0Tr50Evipu6Ojq0]MyFakeUSer@H...[/url
Sent: Thursday, October 23, 2003 6:12 AM
Subject: [noparse][[/noparse]basicstamps] Connecting BS2 to BS1
Pause 100
let B0 = B0 + 1
P.S.
typos. :-)
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
