help with psx controller interface + 1 more question
Thanks Jon, Finally got it to work, I used a controller extension
just like you mentioned, and figured out what pin went where using a
voltimeter set to continuity test. funny thing was that on my
extension cable, orange went to ground and yellow to 5 volts, while
the black cable was the psxdat.
I solder to copper boards to, but like to prototype everything to a
breadboard before doign any soldering of course.
Question: is there any way to activate the vibration function on the
controller that anyone knows of? is it just a command that has to be
send trough the cmnd and clock?
Carlos
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Sometimes we have to solder things.... You can probably use any
> general-purpose NPN for the invertor.
> -- Jon
> From: Super Chorizo [noparse][[/noparse]mailto:carlosbecker@h...]
> Sent: Saturday, October 18, 2003 6:43 PM
> Subject: [noparse][[/noparse]basicstamps] Re: help with psx controller interface
> Thanks Jon.
> that photo actually kind of confused me cause I am used to just
> working on a regular breadboard with the stamp.
> so basiclly all the extra stuff I need is the resistors:
> two 220
> two 4.7 k
> one 470
> and one 2n3904 transistor (any?)
> thanks
> Carlos
<jwilliams@p...>
> wrote:
> > What I did for a connector is hacked a cheap ($8) extension
> cable. I
> > glued it to an AppMod proto board and hand-wired the rest. The
> cable
> > colors are not always consistent, except that 5v is always red,
and
> > ground is always black. You can use those to get your alignment
> > correct.
> > I'll take a photo of my adapter and upload it to the files
section
> (my
> > old digital cam had given up the ghost so I couldn't provide a
> photo for
> > my N&V article).
> > -- Jon Williams
> > -- Parallax
> > From: Carlos Giffoni [noparse][[/noparse]mailto:carlosbecker@h...]
> > Sent: Tuesday, October 14, 2003 10:11 PM
> > Subject: [noparse][[/noparse]basicstamps] help with psx controller interface
> > Hey I need some help in the hardware side, I got the latest
> example code
> > from the n & b site (the one where that invers the shiftin
> manually so
> > there
> > is no need fo rthat extra component (2n3904)) and I get it, but
I
> am
> > confused on how to wire the controller I am assuming I need to
> cut the
> > plastic up til the point where all the connecting pins can be
> soldered
> > to
> > cables and then just follow the image( taking the 2n3904 off
and
> just
> > adding a resistance there straight into one of the stamp pins)
> looks
> > like
> > pin 1 of the controller is connected to 5 volts and then to the
> stamp at
> > the
> > same time to? no resistor before the input pin?
> > just want some pointers before I make a stupid mistake and brake
> my
> > controller, or even worst the stamp...
> > thanks
> > Carlos
> > _________________________________________________________________
> > Get 10MB of e-mail storage! Sign up for Hotmail Extra Storage.
> > http://join.msn.com/?PAGE=features/es
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the
> Subject
> > and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
> > This message has been scanned by WebShield. Please report SPAM
to
> > abuse@p...
Subject
> This message has been scanned by WebShield. Please report SPAM to
> abuse@p...
Carlos
> -- Jon
> Thanks Jon.
> two 220
> two 4.7 k
> one 470
> thanks
> Carlos
<jwilliams@p...>
> cable. I
> cable
and
> > correct.
section
> (my
> photo for
> > my N&V article).
> > -- Jon Williams
> > -- Parallax
> example code
> manually so
> > there
I
> am
> cut the
> soldered
> > to
and
> just
> looks
> > like
> stamp at
> > the
> my
> > thanks
> > Carlos
> Subject
to
> > abuse@p...
Subject
> abuse@p...
I haven't given up. Activating them is far more complicated than
reading switch and pot values from the controller.
-- Jon Williams
-- Parallax
From: Super Chorizo [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kEflgEAJwj6fxkCywUUBVvE-LgyNboKowpGX7Et7rE-zKHZrNN8lmx3_FFRL-RJkFrIBfDGM8ZZIpmgsDnVQWRW0sg]carlosbecker@h...[/url
Sent: Wednesday, October 22, 2003 5:32 PM
Subject: [noparse][[/noparse]basicstamps] Re: help with psx controller interface + 1 more
question
Carlos
> -- Jon
> Thanks Jon.
> two 220
> two 4.7 k
> one 470
> thanks
> Carlos
<jwilliams@p...>
> cable. I
> cable
and
> > correct.
section
> (my
> photo for
> > my N&V article).
> > -- Jon Williams
> > -- Parallax
> example code
> manually so
> > there
I
> am
> cut the
> soldered
> > to
and
> just
> looks
> > like
> stamp at
> > the
> my
> > thanks
> > Carlos
> Subject
to
> > abuse@p...
Subject
> abuse@p...
abuse@p....
