7 segment LED question
I am baffled by a programming question, maybe somebody here can send me in the
right direction.
I have a 7 segment LED driven through a 7447, which has 4 input lines.
And I have any good old number in a word in my program. What do I have to do to
get that number displayed on my 7 segment LED.
I guess first of all I should hock up a second display, one for each byte of the
word.
But then I need to extract the four bits of each byte and get them on my four
input lines of the 7447, but I don't know how.
TIA Uwe
right direction.
word.
TIA Uwe
want to show on the 7 segment display. You can look on the data sheet for
the proper inputs if you don't know BCD. Then, call each subroutine as
necessary to display the character you want. The subroutine should return
to another that turns off the outputs to return the display to zero if that
is what you want. Set up a board with LED's on the outputs and experiment
until the proper outputs are on and you may understand a little better how
it works.
jim
http://www.geocities.com/jimforkin2003/
From: othello159 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jNwy7adriXNKa48n5zQtYQgckuiqvdbcnyUjcDTXZpZQeRb8tyj3GVcxqWl23eCw4dg37m04rULV4fs65g]othello159@h...[/url
Sent: Monday, October 20, 2003 11:25 PM
Subject: [noparse][[/noparse]basicstamps] 7 segment LED question
the right direction.
to get that number displayed on my 7 segment LED.
the word.
four input lines of the 7447, but I don't know how.
TIA Uwe
Once you have your word broken down into two bytes, you can acess the upper
and lower nibble of each byte as:
One_Byte var word
upper_nib var nib
lower_nib var nib
to access the upper for bits
upper_nib = One_Byte.highnib
lower_nib = One_Byte.lownib
Then if you have your 7 seg 4 input lines connected to the stamp pins 0 ~ 3
and configured for outputs, for example you can then send out the data as: (I
think when you say outa that will automatically make the pins output, somebody
else chime in please).
outa = lower_nib
stamp pins 4 ~ 7 have the label outb
outb = upper_nib
Cheers,
ken
the word.
myNumber VAR Byte ' bcd value
dig10 VAR myNumber.HIGHNIB ' 10's digit
dig01 VAR myNumber.LOWNIB ' 1's digit
The nibble declarations assume that the value stored in myNumber is BCD.
If it isn't, then you have to declar them separately and extract with
code. Like this:
myNumber VAR Byte
dig10 VAR Nib
dig01 VAR Nib
Get_Digits:
dig10 = myNumber DIG 1
dig01 = myNumber DIG 0
As pointed out below, if your connections to the 7447 are clever [noparse][[/noparse]that
is, aligned on the output nibbles] you can actually move your value to
the display through a single line of code:
Update_Digits:
OUTL = myNumber
To do this you would connect pins 0-3 to the 1's digit driver (A-D
inputs), and connect pins 4-7 to the 10's digit driver.
-- Jon Williams
-- Dallas Office
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FfqYT-YpJW1Iur1fBm_Yz9F1VPHN_mwYMaLoRGUoWm2QtlabJHeSmIKFZXASPXpPVpsgwU_n]smartdim@a...[/url
Sent: Tuesday, October 21, 2003 7:48 AM
Subject: Re: [noparse][[/noparse]basicstamps] 7 segment LED question
Othello,
upper
One_Byte var word
upper_nib var nib
lower_nib var nib
~ 3
as: (I
somebody
outa = lower_nib
outb = upper_nib
Cheers,
ken
in
to do
byte of
the word.
four
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
7-segment LED display.
But I think I still will have to go back to the books because the display counts
in hex.
As Jon mentioned, the nibble value needs to be in BCD and I guess I did not
understand how to get from a binary number stored in a nibble to a BCD
representation.
But everything else went well and with 8 pins gone for this display and 7 others
for 3 individual A/D converters I will have to look into simplification.
Changing the A/D converters for something like the TLC 2543 might give me back a
number of pins but maybe someone here knows how to make the display more
efficient, more numbers with less pins would be great.
Thanks again
Uwe
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...> wrote:
> You can save variable and code space by aliasing the nibbles like this:
> code. Like this:
> myNumber VAR Byte
> dig10 VAR Nib
> dig01 VAR Nib
> Get_Digits:
> Update_Digits:
> OUTL = myNumber
> -- Jon Williams
> -- Dallas Office
> From: smartdim@a... [noparse][[/noparse]mailto:smartdim@a...]
> Othello,
> upper
> One_Byte var word
> upper_nib var nib
> lower_nib var nib
> ~ 3
> as: (I
> somebody
> outa = lower_nib
> outb = upper_nib
> Cheers,
> ken
> in
> to do
> byte of
> the word.
> four
> abuse@p...
SHIFTOUT. Using this command and two external ICs called a 74HC595, using just
THREE
stamp pins you can control 8, 16, 24, 32........48 output pins.
The 74HC595 is a serial shift register. The Parallax web sight has the code
and shows how to hook up one or two of these (exactly what you need "more
numbers with less pins would be great). My suggestion would be to use the
74hc595's to directly drive the two seven segment displays.
See http://www.parallax.com/dl/docs/books/sw/exp/23b.pdf
This explains the use and operation of the 595's and is well written.
You can use a lookup table or other scheme to make the display show what you
want.
Ken
Thank you very much, I worked with the suggestions and now I have a two digit
counts in hex.
representation.
others for 3 individual A/D converters I will have to look into simplification.
a number of pins but maybe someone here knows how to make the display more
Thanks again
Uwe
