I have only 1 problem any more..... thks to the group
I have one problem:
I want to measure a voltage from an electronic circuit. When the
voltage is above 2V I want to write the time to EEPROM. When de
voltage is again lower than 2V I also want to know the time.So, I
just want to know how many seconds the voltage is above 2 volt. Is
it possible to do this?? Can I do a time measurement?
Thks
Thks
output to pin -) and threshold 2V in pin +))before the Parallax's pin then
you put directly your input to pin - of OPAMP and you connected the out put
to any basic stamp's pin and use the comand to time measurement,,,,,
best regards
Atentamente.
Ing. Damian Trujillo G.
RIESE & CIA, S.A.
Caracas - Venezuela
) +58-212-7934266/4377
7 +58-212-7940791/0908
+ dtrujillo_riese@c...
Date: Lunes 20 de Octubre de 2003 02:15:00 PM
Subject: [noparse][[/noparse]basicstamps] I have only 1 problem any more..... thks to the group
I have one problem:
Thks
