SV: [basicstamps] Re: New to BS1 Help
Greetings!
Why not just make a boot diskette for the PC?
A 1.44MB holds a 'mini' install of DOS, the BS1 IDE and all your .BS
program files with lots of space to spare...
If worst comes to show, use a M$-DOS install diskette, press F5 while
booting, then insert a floppy with the IDE after the PC have finished
ignoring the setup scripts...
Trygve
Opprinnelig melding
Fra: Gary W. Sims [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4kEuxqrcZyBweTTU7-H-ayAcLAeKcMrD_NpWEzVDyRyhHcXx13Gq-Mv0_0IrqNpkdybyOz_2y8rO93BvPw]simsgw@c...[/url
Sendt: 20. oktober 2003 07:53
Til: basicstamps@yahoogroups.com
Emne: Re: [noparse][[/noparse]basicstamps] Re: New to BS1 Help
> So what's a guy to do then?
> [noparse][[/noparse]...]
> I'm using Windows XP, I have NTFS partitions, I am not going back to
> archaic versions of MS software.
> Should I just return the stuff (BS1 Starter kit) to the retailer?
> Why would Parallax even allow obsolete stuff like this to stay on
> retailers shelves?
Well, the software is free -- and the BS1 itself isn't obsolete, just
not the latest model. You might have more fun playing around with the
BS2 because it has more features, but not necessarily. It's fun doing
the minimalist thing once in a while. Either way, I wouldn't return the
BS1 because of the software issue.
Like you, I run XP and I don't have the choice of dual-booting into DOS
because my hardware configuration is not DOS-compatible. (NTFS
completely, and a RAID drive configuration as well...)
On the other hand, I'm being patient. The new version of the
editor/compiler is a very nice product, even though it's still in beta
right now. I deleted the version in retail distribution because the beta
is trouble-free and much nicer. Currently that version supports only the
BS2 models, but Parallax have added support for the older BS1.
Unfortunately, that feature is only in alpha test right now and not
available to customers -- even in beta. I understand it will be
available in a few weeks.
Personally, I keep looking at the old machine in the corner and thinking
about loading the DOS mode BS1 software onto it. Then I remember what a
pain DOS is, and I only have "a few weeks" to wait. I can't imagine a
software schedule slipping, can you?<sigh>
Ah well, the BS2 is keeping me entertained meanwhile.
Gary
Your use of Yahoo! Groups is subject to
Trygve
Opprinnelig melding
> retailers shelves?
Gary
There's also the DR-DOS option...
http://stud3.tuwien.ac.at/~e0225895/drdos/drdos.htm
(The DR-DOS club where you can find links to download DR-DOS or
OPEN-DOS)
Works good.
Trygve
Opprinnelig melding
Fra: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6ZWfdwb5HZ84O-hE151st4guM7yE_AeXgjFpJ_jkN5J-1R5XtlATUMr81V-eo8ZXGt0aC4ibdgwU]alw@a...[/url
Sendt: 20. oktober 2003 13:42
Emne: RE: [noparse][[/noparse]basicstamps] Re: New to BS1 Help
One idea: create a Windows 98 (or earlier) boot floppy (assuming you
somewhere have a license for such) and copy the Parallax software to it.
Boot from the floppy. You won't be able to see your hard drives but you
will be able to write your code and compile/download it. Just think of
it as retro.
If you have a license and don't have a computer that can create the boot
floppy for you, you could probably find a copy on the Web -- search for
"boot disk" in google and you should find something.
Al Williams
AWC
*Electronic Kits - http://www.al-williams.com/kits.htm
> From: kggsystem [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pByb9T_OoSubhQaTx5LgNz_aTswogP8a8aw55iZv-dbZcuTETkFjnDXEqar2yEUTsAY2uW2t]kevgor@s...[/url
> Sent: Sunday, October 19, 2003 12:44 PM
> Subject: [noparse][[/noparse]basicstamps] Re: New to BS1 Help
> When I first bought my BS1 Starter kit, I went to the store and the
> salesman didn't tell me that you need to go back to software you
> erased off your computer three years ago, he didn't tell me that the
> development system is only DOS based. Frankly I doubt he had a
> clue...
> retailers shelves?
> --- In basicstamps@yahoogroups.com, Kyle Cooper <crazykurby@y...>
> wrote:
> > I did the same thing so I called and asked and the program only
> works with 3.1 to 98 or
> > systems with full dos but it doesnt work with xp but it does work
> with millenium edition
> > havent tried it on windows 2000 though.
> > Jon Williams <jwilliams@p...> wrote:
> > BTW ... ALT I was used to program PIC16C58 when the original
> Parallax
> > PIC programmer was available.
> > -- Jon Williams
> > -- Applications Engineer, Parallax
> > -- Dallas Office
> > From: Brian D [noparse][[/noparse]mailto:brian3812003@y...]
> > Sent: Sunday, October 12, 2003 3:49 PM
> > Subject: [noparse][[/noparse]basicstamps] New to BS1 Help
> > I just discovered basic stamps and need a little help.
> > I am using BS1-IC
> > parallel cable connections:
> > cable # 25 to BS1 Pin 2
> > cable #11 to BS1 Pin 3
> > cable # 2 to BS1 Pin 4
> > 9 volt + to BS1 Pin 1
> > 9 volt - to BS1 Pin 2
> > I am running Window XP
> > from with in the Command Prompt, Basic program and my program
> loaded, I
> > get the following: When I hit ALT I to program the IC the screen
> says
> > PIC16C58A when m chip has printed on it PIC16C56A, it will mot let
> me
> > change this. If I hit the space bar as directed to program the
> chip and
> > error "PIC16CXX-PGM not found
> > I hit ALT R and I get : error message "hardware not found"
> > what am I doing wrong?? Please help
> > Thank you,
> > Brian
> > brian3812003@y...
> > Do you Yahoo!?
> > The New Yahoo! Shopping - with improved product search
> > [noparse][[/noparse]Non-text portions of this message have been removed]
> Subject
> > This message has been scanned by WebShield. Please report SPAM to
> > abuse@p...
> > Do you Yahoo!?
