Quick Question about a DC Motor
If you reverse the leads on the motor DC motors will reverse direction. This
can be done with a relay or a group of transistors.
Jim Johannsen
jim@j...
From: MP1428@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tr4O-r91ZN7x39tdREGvDBDpgcyZfrAkRPV2QxVebrodCx4vt_6rpKnEIUtlTrj9p19GmHfJDSXT]MP1428@a...[/url
Sent: Sunday, October 19, 2003 5:18 PM
Subject: [noparse][[/noparse]basicstamps] Quick Question about a DC Motor
I'm a beginner with motors, and I just need to produce a simple forward and
backward rotation; I don't care about accuracy. I understand that a DC motor
is
simpler to use than a Stepper Motor? And if that's true, my next question
is:
Is it possible to rotate a DC motor in the backward direction?
Jim Johannsen
jim@j...
is
is:
backward rotation; I don't care about accuracy. I understand that a DC motor is
simpler to use than a Stepper Motor? And if that's true, my next question is:
direction. One of many ways to do this is with a double pole double throw relay.
If you choose this method, be sure to include a diode across the relay coil.
The diode is connected cathode (end with a line) to the positive side of the
relay coil.
Ken
In a message dated 10/19/2003 5:19:08 PM Pacific Daylight Time,
MP1428@a... writes:
is
direction. This
> Jim Johannsen
> jim@j...
The common way is an H-Bridge. very simple, uses 4 main transistors,
2 pnp, 2 npn.
although an H-Bridge in not inherently a speed control, you can
puslse the transistors to get a sorta speed control.
Google H-bridge.
the more power you want to use, the more protection you should think
of adding.
The only problem with relays is that the relays are mechanical and
may fail. but the trade off for a little less silicon is a little
more space and money. (ie: resistors are more $$ and bigger)
Dave
> From: MP1428@a... [noparse][[/noparse]mailto:MP1428@a...]
forward and
DC motor
> is
question
> is:
Subject and
main transistors,
2 pnp, 2 npn."
But if you are new to electronics a relay may be your best bet at this time,
and if the relay fails (which is very rare) the motor will simply turn only
one direction depending on the relay failure.
An "home brew" H bridge if not properly designed or controlled will ruin your
transistors if you get the wrong pair turned on at the same time, however,
with some logic gates to control the H bridge, this should never happen.
If you use a LMD18200 from National, you should not have any worries and is a
better solution than a relay, but a little pricey.
http://www.national.com/ds/LM/LMD18200.pdf
Also check out http://www.dprg.org/tutorials/1998-04a/
Google H-bridge.
of adding.
Dave
opposite direction. For schematics to control these with a stamp check out
http://www.geocities.com/jimforkin2003/
jim
From: MP1428@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=y_SbelyS5_-dQRQA65HxZigH1PD5dOLmeYz7d0nZ5XWQhnt6PrP7HwkE0Y_kF_FRmnaJf-A0lG8]MP1428@a...[/url
Sent: Sunday, October 19, 2003 8:18 PM
is
is:
can rotate DC motor backward.
a very easy way is using a DPDT switch see the
oscar
panama city, rep. of panama
--- MP1428@a... escribi
jim http://www.geocities.com/jimforkin2003/
From: Oscar Andrade [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gHTLrGnCEZ_3cYBRYmFabQUuaqHz051YCNtH3sF4tzpGknffIPeigNYx2fBRPx4wn0XsvGM37HS83XHCGmw]oscar_andrade@y...[/url
Sent: Monday, October 20, 2003 9:07 PM
Subject: Re: [noparse][[/noparse]basicstamps] Quick Question about a DC Motor
yes, DC motor are simpler then steppers and yes you
oscar
