Connecting 16 SSR to Basic Stamp
Hi there,
I want to connect 16 Solid State Relays to BS2p 40 but I am don't
want to exceed the Stamp current rating ( 75 mA ) So, does any one
have an Idea .... and Also does anyone know a ready board that have
16 SSR that are ready to connect to Basic Stamp ..
Please Reply ASAP
Demolition007
Please Reply ASAP
Demolition007
http://www.parallax.com/detail.asp?product_id=27966
--- Deep Blue <demolition007@y...> escribi
have relay projects. schematics for connection can be found here
http://www.turbodeuce.com/images/bs2_to_relay.jpg
good luck, Gary D
At 11:44 AM 10/16/2003 +0000, you wrote:
> Hi there,
>Please Reply ASAP
>Thanks,
>Demolition007
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I think you will find that one easy way to drive many outputs would be
to use a couple of shift registers like the 74HC595. There is even an
example in the Stamp manual in the SHIFTOUT section. You will want to
check the current limit on the 74HC595 but there are a plethora of
driver chips available. Hope this helps.
--- In basicstamps@yahoogroups.com, "Deep Blue" <demolition007@y...>
wrote:
> Hi there,
> Please Reply ASAP
> Thanks,
> Demolition007
Are you looking to use solid state I/O modules? If so are any of them Inputs?
Opto-22 makes a G4 Solid State I/O board. It uses a 50 conductor ribbon cable
and headers.
If you need Inputs then put at least 2 input modules in with each group of 8
I/o Pins. This will insure that the other 6 modules will not over work the
Stamp2P output capacity. Each Output module draws about 13 ma max. You should
use
an external +5 volt regulator. That way you have 100 MA per 8 pin group. The
I/O modules and the Mounting Rack will set you back some $$, so don't skimp on
the power. The Rack has its own pull up resistors so you can connect the
modules directly to the stamp pins.
www.opto22.com
Ordering - Product Search Results
I have made a PC board with the 50 pin header and use BS2p-24 with this rack.
It works very good.
Hope this helps,
Alan Bradford
Plasma Technologies
Canaan NH
In a message dated 10/16/2003 11:14:18 AM Eastern Daylight Time,
demolition007@y... writes:
Hi there,
Please Reply ASAP
Demolition007
the BS2 is with the PCF8574(A) 8 bit I/O expander from Texas
Instrument. This little device is controlled by using the I2C bus so
it only uses 2 IO pins on the BS2. It is possible to daisy chain 16
chips together for a total of 128 I/O lines using only 2 I/O on the
BS2. NOTE: that will be using (8) PCF8574 and (8) PCF8574A. each bit
is individually programmable and latched at the output.
This is what I am currently using to control 8 CFL outdoor lights
around my house. The BS2 interfaces with 8 25 amp SSR. (I know
overkill but they were free) The PCF8574 has high current outputs,
total of 100ma, plenty to directly drive LEDS, SSR, etc. of course if
you need more current drive you can always tie in (8) 2N2222 NPN's
This chip, PCF8574, is available from www.digikey.com for only $2
http://www.digikey.com/scripts/us/dksus.dll?Detail?
Ref=117374&Row=50850
The datasheet can be found at
Daryl
--- In basicstamps@yahoogroups.com, "leharker" <harker@a...> wrote:
> Demo,
be
an
to
> wrote:
> > Hi there,
one
have
> > Please Reply ASAP
> > Thanks,
> > Demolition007
