Serializing Sensors with a bs2sx stamp
Does anyone know of a device that will allow you to combine many
sensors to communicate on one I/O Port of a BS2SX Stamp? The device
would have to do this while still allowing the stamp to know which
sensor is triggered. I don't have enough I/O ports to put on all
the sensors that I want. Thanks.
Sam
Sam
possible CS features using a demux IC (3 to 4 ports) to select up to 16
sensors. A lot depends on the sensor you are trying to use and what
requirements it needs. Also the One Wire devices are able to be placed on a
bus and activated by a match rom command to talk to each sensor separately.
Again what is your application and number of sensors and sensor types you
want to use.
Sent: Wednesday, October 15, 2003 7:35 PM
Subject: [noparse][[/noparse]basicstamps] Serializing Sensors with a bs2sx stamp
> Sam
sambo_commando@y... writes:
Sam
Sam,
If the timing of the additional input signals is not SUPER critical, you can
use a serial shift register. Using jus a few stamp lines (3 I think) you can
expand to 8, 16, 24, 32 ........additional inputs. The Parallax web sight has
the schematic and code example.
Ken
