Wrong supply voltage on my stamp — Parallax Forums
edited 2003-10-15 00:49 in General Discussion
Me and my fellow students were experimenting with our bs2p24 stamp
hooked up to our learning board and we accidentally put 9 VAC
instead of 9 VDC into the power supply. It worked for a little
while and now we can't seem to get the program to recognize the
stamp. It keeps on telling us that the stamp is not there.
Has anyone ever done this too? Can we salvage the board/chip, or is
it fried?
Sam
    edited 2003-10-14 16:37
    get a VOM (volt ohm meter) and check the voltage at VDD. you should get 5
    volts there, if not you fried the on board regulator. also by putting the
    AC line on the stamp your telling the stamp to operate at 60 Hz and you
    might have fried the clock.
    >it fried?
    >Thanks,
    >Sam
    >from the same email address that you subscribed. Text in the Subject and
    >Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    edited 2003-10-14 17:16
    In a message dated 10/14/2003 8:44:59 AM Pacific Daylight Time, gdii@c...
    writes:
    In the past Parallax has been pretty good about accepting your fried Stamp
    and selling you another one (rebuilt?) at less than the cost of a new one. You
    may want to contact Parallax customer service.
    I put a volt meter on the vreg and it was reading 5V like it
    should. I am beginning to accept the inevitable answer to my
    question. The stamp gets pretty hot when we turn it on and I don't
    think that's right. Thanks for the info.
    Sam
    gdii@c...
    > writes:
    should get 5
    putting the
    and you
    fried Stamp
    new one. You
